brake failures 2019 models
Old Nov 10, 2018 | 02:26 PM
Cazador's Avatar
Cazador
Member
Originally Posted by SBRob
Yea, that's located next to the wiper fluid switch on the left..............
That's why it's only on touring models. The others don't have windshields.
Old Nov 10, 2018 | 03:28 PM
GTK's Avatar
GTK
Just sounds as if the OP doesn't know too much about the mechanical workings of a motorcycle.
Old Nov 10, 2018 | 03:44 PM
EasternSP's Avatar
EasternSP
Now that ya all have run your mouth on what ya think ya know, Harley has a recall out on a diaphragm that goes in the clutch fluid reservoir for the 2016 model at least. Just as the OP described it, a bad diaphragm will cause bike lurch when starting in gear which can be done. So next time ya all take your bike in for an oil and filter change by the dealer, have them check that clutch fluid reservoir. Then you can sit in the waiting room and tell people how much ya know about changing air in your tires.
Old Nov 10, 2018 | 03:50 PM
SBRob's Avatar
SBRob
And the OP said specifically brake failure.................................
Old Nov 10, 2018 | 05:48 PM
Screamin beagle's Avatar
Screamin beagle
And here I thought the 2019s had some of them new fancy secondary hydraulic brakes everyone's been talking about...i guess I'll wait for 2020s
Old Nov 10, 2018 | 05:56 PM
purpledeuce's Avatar
purpledeuce
do you really think the moco is gonna start using higher quality parts? If you want a new HD, buy it and then go to the aftermarket for better fixes. I can tell you this, I’ll never buy another new harley. It’s ridiculous to spend over 23 grand and then drop more to make it run proper and safe
Old Nov 10, 2018 | 06:26 PM
TriGeezer's Avatar
TriGeezer
The OP blamed it on hydraulic brakes! He referenced hydraulic brakes several times...not clutch! That why we had our fun with him.
Lighten UP!
Sandcrab's Avatar
Sandcrab
Why would anyone want to start their motorsicle NOT being in neutral?
One example is when you are waiting for a green light while stopped on a hill and stall the bike when starting out. Car behind honks. Bike drifts slightly rearward. The heat is on, stress builds, horn honks again..
Much easier to just pull in clutch, hit starter and be on your way.
The other method would be to try and find neutral, shifting from 1st into second, back into first, constantly missing neutral. Finally you shift into neutral while trying to holdi the bike from rolling back, start the bike, shift into first, and go.
Just saying there are times when starting in gear is the preferred method.
Old Nov 10, 2018 | 06:43 PM
Bob Blehead's Avatar
Bob Blehead
Meh, just take it to the stealership, they'll fix it for ya'.
Did ya not scroll down and see in his post signature where one of the the dealers minions
was working on the bike??????
Old Nov 10, 2018 | 06:48 PM
sportglide's Avatar
sportglide
Default I meant Hydraulic Clutch - my bad
Originally Posted by sportglide
I was crazy tired this morning when I started this thread and can not figure out how to delete or change the thread title.
I know of two 2019 RGS that had the secondary Hydraulic Clutch actuator fail - causing the bike to launch at start up; mine being one of them.
Yes the clutch was pulled in so the interlock "thought" the clutch was disengaged.
No recall has been issued for any of the 2019 touring bikes with hydraulic Clutch "YET" that I am aware of.
Anyone else?
Standby.
Anyone else?
