Custom Handlebars
Old Nov 30, 2018 | 08:14 AM
CyGlide's Avatar
CyGlide
Default Custom Handlebars
Could anyone point me in the right direction of a company who can custom fabricate bars for a 2017 Ultra Limited? My dad needs to have custom bars made so that he can comfortably and safely ride the bike. We've tried the Wild 1 chubbies with the 2" pullback and they just don't have the right angles on them, so he is just going to bite the bullet and have some custom made. We are located in Iowa, but he is willing to travel to where ever a good shop is that could take measurements and fab the bars.
Old Nov 30, 2018 | 08:33 AM
Jshopes's Avatar
Jshopes
Try vindikta or i think the name is br custom bars. A google search will turn up ALOT.
Old Dec 1, 2018 | 01:34 AM
BikerPepe`'s Avatar
BikerPepe`
Did you try to contact WildOne directly and discuss the issues and see if they're willing to work on something with you? I've had excellent customer experience with them in the past and since you've already invested, they may be more willing to see if they can meet your needs. Just a thought... unless you have money to burn.
Old Dec 1, 2018 | 01:47 AM
nobodyknowsme's Avatar
nobodyknowsme
I mess with EMT at work and in the past have bent some, about enough to know just how much talent it takes to know that I needed to limit my abilities. Point is that if I wanted to create custom bars that it may be worth bending some pipe to see if I could create what I wanted. Then I could see if I could have a true set mocked up.
Old Dec 1, 2018 | 01:51 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
I had the Helibars installed on my '18 Tri-Glide.
Expensive but they're very adjustable and make you feel like the machine was made just for you.
FWIW, I have the W.O. 577's on my '13 CVO Ultra and they fit me very well.
I think they have a 12.5" Rise and they sit above the "break" of the fairing.
I think I may have been able to use the W.O. 578's that I believe have a 10.5" Rise but I was concerned that they may not have the amount of ride that I wanted.
The amount of labor time is a little less (or should be) with the Helibars as they do not use internal wiring but the plastic conduit on the later model H-D's looks pretty cool IMO.
Either way you go, when changing the handlebars is also a good time to add heated grips and a remote garage door opener as they already have the upper fairing pulled into the rest position.
Old Dec 1, 2018 | 08:37 AM
CyGlide's Avatar
CyGlide
thise heli bars might be perfect. I hadn’t seen those before. Thanks for the reply!
Old Dec 1, 2018 | 08:39 AM
CyGlide's Avatar
CyGlide
they were my first call as I have their bars on both my bikes. They don’t do any custom bends though unfortunately.
Old Dec 1, 2018 | 10:57 AM
nobodyknowsme
Wish I would have known about the Helibars a few sets of bars ago. Sure would have saved a bunch of money!!! They will be on my radar going forward and the darned things should be a huge sticky on every section of the forum.
Jeremy Pyke
Nov 3, 2013 03:01 PM
HOGBOY57
Aug 15, 2013 06:08 PM
Flylearn1
Jan 12, 2008 03:59 PM
Blue
Mar 19, 2006 10:04 AM
