Screamin eagle compensator knock
Old Feb 13, 2019 | 10:32 PM
Rich90805's Avatar
Rich90805
Default Screamin eagle compensator knock
I have a 07 road king stage 1 with s&s 510 chain drive cams
I just installed the screamin eagle compensator .. Barnett Kevlar extra plate clutch and the hayden chain adjuster all in one shot.
So the bike starts up nice now doesn't sound like a can of rocks anymore.. however after idling for about 5min once the bike starts to warm.. I'm hearing knocking pretty loud.. knock...knockknock......knock .... knock knock knock... . The bike is running very well..
Please help
Old Feb 14, 2019 | 05:31 AM
RK_Classic's Avatar
RK_Classic
Are you sure your not hearing the primary chain slapping the primary? reason I ask, I put a hayden adjuster in mine and had to shim the adjuster because I was getting chain slap on idle and startup.
rk classic.
Old Feb 14, 2019 | 05:47 AM
Rich90805's Avatar
Rich90805
That was also in the back of my mind.. I didn't use any of the shims on the hayden. The measurements were on point 3/8" according to the instructions. The chain felt nice and tight. I will open the primary back up maybe tomorrow and hopefully find the issue.
Old Feb 15, 2019 | 06:49 PM
nytryder's Avatar
nytryder
My advice is lose the Hayden. Had one one my '12 RGU. The chain was also tight when cold. i called Hayden for advice and was told not to worry as then chain would "wear in". After about 4500 miles the entire primary system was junk. I went back to stock and have had no problem since.
Old Feb 15, 2019 | 07:35 PM
Rich90805's Avatar
Rich90805
I took the primary cover off today and started the bike... the knocking I was hearing was the hayden bottoming out... I put the stock tensioner on ... no more knocking ..
Old Feb 16, 2019 | 04:19 AM
RK_Classic's Avatar
RK_Classic
Nice, now get some miles in.
rk classic.
Mark Williams
21
Aug 31, 2018 11:42 PM
GalvTexGuy
2014-2024 Touring Models
15
Oct 23, 2017 07:08 AM
Wv7o
Sep 14, 2016 09:25 PM
extremeshot
Apr 28, 2016 01:27 PM
32roadking
Feb 3, 2016 01:59 PM
