Frame Protectors?
Old Feb 26, 2019 | 09:36 AM
BobRR's Avatar
BobRR
Default Frame Protectors?
I have a set of frame protectors that I used on my 2004 Dyna Wide Glide and the 2016 Fatboy. They are called "Dyna Frame Protectors".
I would like to use them on my 2018 Road King.
Of course they fit, but they are a little bit looser on the Road King frame than they are on the Fatboy or (as I remember on the Wide Glide).
Can I use them on the Road King frame? If they are a little loose do I have to be concerned that they might slip on the frame rail when I start to jack up the bike?
Old Feb 26, 2019 | 09:59 AM
LQQK_OUT's Avatar
LQQK_OUT
Why do you need frame protectors on a Road King? Is the issue your jack doesn't have any rubber on the lifting rails?
Old Feb 26, 2019 | 10:07 AM
BobRR's Avatar
BobRR
I always use frame protectors. When I clean the wheels I jack up the bike far enough so I can spin the wheel with my hand.
Old Feb 26, 2019 | 10:20 AM
Red's Avatar
Red
So what are you protecting the frame from?
Old Feb 26, 2019 | 10:22 AM
BobRR's Avatar
BobRR
The frame protectors provide about half an inch clearance between the bottom of the frame rails and the jack.
This is what they look like...
https://www.harley-davidson.com/store/frame-protectors
Old Feb 26, 2019 | 10:29 AM
Red's Avatar
Red
And why is that important?
I've used a bike jack for decades without them. Sounds like it would make getting the jack under the bike more difficult because of reduced clearance.
Old Feb 26, 2019 | 11:05 AM
RichM752's Avatar
RichM752
Now I've seen it all.
Old Feb 26, 2019 | 11:10 AM
RK_Classic's Avatar
RK_Classic
Pitch them in the trash and rely on the rubber grip pads on the lift saddle of the jack.
rk classic.
Old Feb 26, 2019 | 11:11 AM
kngpn's Avatar
kngpn
click the fitment tab in the link you posted
Old Feb 26, 2019 | 11:13 AM
hdbob2006's Avatar
hdbob2006
An old towel,an old chunk of carpet,paper towels,a disposable diaper[un-used!] A plastic sheet style cutting board,old t-shirt etc etc etc!
