changing m8 spark plugs
So...unless you can deduce...service manual does not always have all the answers. Which is why God created forums. So we can ask for advice when things are not totally clear.
Literally taken from the SM:
1. See Spark Plug Cable. Remove cables retainers (5).
2. Remove cables (1–4) from ignition coil.
3. Remove boot from spark plugs.
4. Remove cables.
Figure 2. Spark Plug Cable Routing: (Fuel tank removed for clarity)
edit:
upon further inspection...I was reading the section on plug wires...not plugs. Here is what is says on plug removal:
1. Remove seat. See Remove.
2. Purge fuel system. See Prepare.
3. Remove main fuse. See Main Fuse.
4. Remove fuel tank. See Prepare.
I'll just shut up now.
