Engine codes
Old May 2, 2019 | 09:19 AM
galxl68's Avatar
galxl68
Stage III
Default Engine codes
I looked up the meanings. Can’t find driver circuit low. What is it? Any other help would be appreciated. 2017 RGS.
Old May 2, 2019 | 09:44 AM
Mark out West's Avatar
Mark out West
Guessing here, but one side of your electronic throttle "H-Bridge" driver has a short in it somewhere. Possibly both transistors on one side of the bridge are shorting to ground. Given the other codes though, I'd start with system voltage and confirm that first, then look for loose or broken wiring leading to the throttle motor.
Old May 2, 2019 | 01:13 PM
galxl68's Avatar
galxl68
Stage III
Default ?
Are you talking about the throttle control sensor? And wiring in handlebars? Then from there to throttlbody
Old May 2, 2019 | 01:18 PM
Keithhu's Avatar
Keithhu
I could be wrong, but looks to me like those are historical codes, I'd clear them and see if they come back.
Old May 2, 2019 | 02:28 PM
Mark out West
As Keith pointed out, if you're currently afflicted with this problem, then I'd suggest checking the wiring between the ECU and the throttle-by-wire (ETC) motor on the intake. Look for obvious stuff first, possibly reseat some connectors, that kind of diagnostic. The DTCs point to a non-responsive throttle motor, which I'm assuming is your problem currently.
Old May 2, 2019 | 06:14 PM
FlamedFXR's Avatar
FlamedFXR
If you just have codes and no running issue, clear them out. Most likely wont return.
Old May 2, 2019 | 08:25 PM
galxl68's Avatar
galxl68
Stage III
Twice now the bike went into auto shut down. This time it started up in about a min Than it ran fine with
Old May 2, 2019 | 10:44 PM
Mark out West
Given the reliability and redundancy of the throttle-by-wire system, I doubt this will be an "one-shot" problem. HD's Diagnostic tool probably has more detailed information compared with an OBC reader.
Did you or your mechanic do something with the engine before this started?
Z
Jun 5, 2024 12:50 PM
drew4jan
May 23, 2018 02:11 PM
tensaw
Feb 26, 2018 07:26 AM
FireHogRider
Electrical/Lighting/Alarm
18
May 4, 2017 11:37 AM
rick
Jan 17, 2013 09:49 AM
