2010 tour classic idle only At first i could turn engine off for a few minutes and throttle would return to normal, now when i start the engine it will only idle. any ideas?
ETC is electronic throttle control.
Check the codes? https://www.hdforums.com/forum/ignit...tic-codes.html
Likely candidates for that bike are: the twist grip sensor, a break in the wire harness between the twist grip sensor and the ECM, or the TB.
