Dying while riding
Old May 10, 2019 | 07:01 PM
  #51
Zerk's Avatar
Zerk
It healed it self.
Old May 10, 2019 | 07:10 PM
  #52
NORTY FLATZ's Avatar
NORTY FLATZ
Originally Posted by Buster217
How do you know that?
Seen it happen, first hand. Twice.
First one was a Heart failure. Dead before he hit the guardrail.
Second one was from a bee sting. Acute reaction/shock. Went off into some trees lining Hwy 79, just outside of Temecula. Dead before he hit the tree. (If you have a bee venom allergic when riding, I hope it's a mild one. Dale's wasn't.)
Old May 30, 2019 | 05:12 PM
  #53
Kunalsadhre's Avatar
Kunalsadhre
5th Gear
Hi, seems the problem started again.
My bike dies every 2-3 miles, seems it is running out of gas.... today i checked the fuel pack and getting an error as "fuel pump overloaded"
Questions.
Is this error the cause of bike dying
How do i fix it
Old May 30, 2019 | 05:19 PM
  #54
Halojumper's Avatar
Halojumper
Originally Posted by Cozz
I thought this thread was about somebody dropping dead while in motion.
Me too
Old May 30, 2019 | 05:44 PM
  #55
Crazy's Avatar
Crazy
My bike ('07) was doing exactly that. The system relay was going bad. The relay would shut off the fuel pump and the bike would die. A few minutes later it would come back to life. Same exact thing you're describing. A system relay is a $10 part and plugs into the fuse box.
Old May 31, 2019 | 12:39 PM
  #56
Kunalsadhre
5th Gear
ok, so brought the system relay for $12....but unable to find the spot to plug it in...looked for 1hr..removed battery etc...also checked videos for help....they don't match my 2014 fat boy....
also FYI....the service guy at the dealership said system relay will not solve the problem...as the bike starts after few seconds....
Old Jun 1, 2019 | 02:04 AM
  #57
Crazy's Avatar
Crazy
Try this: https://www.hdforums.com/how-tos/a/h...diagram-413189 The system relay is #11 in the diagram. Re:"the service guy at the dealership said system relay will not solve the problem...as the bike starts after few seconds..." Which is exactly what mine did. And if that doesn't fix it, it's only a $12 part.
Good Luck
Old Jun 1, 2019 | 04:55 AM
  #58
Touten2's Avatar
Touten2
Let "the guy at the dealer" fix it. Seems like he knows everything anyway.
Old Jun 3, 2019 | 12:30 PM
  #59
Kunalsadhre
5th Gear
so i finally gave up and took it to the dealership.....seems the fuel regulator and pump both are not working....total cost to fix it is $900
Old Jun 4, 2019 | 12:12 AM
  #60
Ragtop's Avatar
Ragtop
I had a Wideglide that did something similar. Riding down the road, all of a sudden it would die, shut right off,
One day I was so pissed at this, I slammed my fist on the ignition switch, guess what, it came right back to life!
Swapped out the switch and the problem never came back,
