Engine knock
Old May 6, 2019 | 12:03 PM
Nick Palladino's Avatar
Nick Palladino
5th Gear
Default Engine knock
Just rebuilt top end of my 1994 sportster 1200. Runs great but knocking sound from engine. Cyclinders were bored and valves redone at machine shop. Knock is barely noticeable in neutral but when you put in gear and take of it gets worse. Any advice.
Old May 6, 2019 | 01:12 PM
RHPAW's Avatar
RHPAW
Knock, knock...
Who's there?
Rod...
Rod Who?
Rod Knock.
Boom.
Old May 6, 2019 | 01:15 PM
RANGER73's Avatar
RANGER73
When the head work was done did they use adjustable pushrods?
Maybe a locking nut came loose.
Old May 6, 2019 | 01:49 PM
Mattbastard's Avatar
Mattbastard
Old May 6, 2019 | 02:46 PM
Nick Palladino
5th Gear
Originally Posted by RHPAW
Knock, knock...
Who's there?
Rod...
Rod Who?
Rod Knock.
Boom.
my first thought, but strange it was fine before rebuild
Old May 6, 2019 | 02:52 PM
Nick Palladino
5th Gear
I put original non adjustable rods back in. Again I did not knock before rebuild
Old May 6, 2019 | 03:39 PM
carlgrover's Avatar
carlgrover
My EVO road king is the same way. Motor was rebuilt, runs fantastic but scares me to death at idle with all of the knocking/banging noises it's making. Runs great at speeds though. Asked my Dad about it and he mentioned it could be the oil. I'm just going to keep on running it.
carl
Old May 6, 2019 | 03:58 PM
Tommy C's Avatar
Tommy C
The machinist might have set the piston to cylinder clearances to loose & what you are hearing is piston slap. It's harmless but annoying.
Old May 6, 2019 | 04:19 PM
RHPAW's Avatar
RHPAW
Years ago, I was coming home from somewhere, and still one state away when I started hearing that one unmistakable sound. My Shovel had 147,000 on that bottom end, and I knew it was time. The thing is, it only knocked when I was leveled off, not on the throttle or off the throttle. So we kind of surged our way home, while I prayed that it stayed together. It never smoked, and still had good power, but the oil pressure went to zero at idle.
Well, we made it. When I split the cases later, there was a .030" deep groove in the crank pin. All the innards are new now, so we're good.
Old May 6, 2019 | 04:36 PM
Trench's Avatar
Trench
If it's knocking it's not "running great"
ETA: if it's a heavier knock when you twist the throttle under load it could be bottom end/rod...Piston slap as someone above mentioned usually gets quieter as the engine heats up..can you post up a video with audio of this knock?
