Led problems
Old Jun 1, 2019 | 03:15 PM
Robert Kaneshiro's Avatar
Robert Kaneshiro
1st Gear
Default Led problems
I replaced all my lights with LEDs and recently have been getting the check engine and battery lights on my dash. I checked the codes and it reads P0563 high voltage. I checked the voltage to my battery and it reads12 volts at idle and goes up to 13 when I rev it. Any ideas?
Old Jun 2, 2019 | 06:56 AM
wizardfitz's Avatar
wizardfitz
Not even close to being a mechanic, but it is an older bike? I remember hearing LEDs draw less current and needs an equalizer.
Old Jun 2, 2019 | 07:23 AM
Kingface's Avatar
Kingface
You need a signal stabilizer
https://www.customdynamics.com/stand...vidson?cat=106
Old Jun 2, 2019 | 07:27 AM
Robert Kaneshiro
1st Gear
I have been doing research on what kind I need but havent been successful. Im hoping someone will be able to answer that question for me!! Thank you.
Old Jun 2, 2019 | 07:29 AM
1plumr1's Avatar
1plumr1
custom dynamics--plug and play
Old Jun 2, 2019 | 07:32 AM
Robert Kaneshiro
1st Gear
Thank you. Im wondering if I need one for the headlight? I started having problems with the codes after installing the LED headlight? My turn signals work fine.
Old Jun 2, 2019 | 08:10 AM
Kingface's Avatar
Kingface
I put a link to the one you need in my post.
Old Jun 2, 2019 | 08:38 AM
Robert Kaneshiro
1st Gear
Ill try it thanks.
Old Jun 2, 2019 | 09:15 AM
GregGillette's Avatar
GregGillette
I did headlight, tail light, spots and front turn signals without issue or errors. When made my way to rear signals, hyper flash and errors. I used these load resistors to solve. I added at the rear under seat tapped into the wires that fed the rear signals (common to fronts).
Old Jun 2, 2019 | 10:01 AM
Robert Kaneshiro
1st Gear
I have a ave a unit that turns all my lights including the turn signals into running lights for greater visibility. Would I have to remove it or piggy back on it? Thanks!!
