Drag Pipes, Baffles and FP3.....
Old Jun 18, 2019 | 03:26 PM
GoldieG's Avatar
GoldieG
1st Gear
Default Drag Pipes, Baffles and FP3.....
Evening all,
I’ve been searching around and not found too much information on this.
Drag pipes, look great but very loud (too loud for some) and drop in performance. Has anyone had experience doing this - LAF drag pipes, with torque cones at the header end, and standard baffles fitted near the exhaust exits.... with an FP3 tuner......
anyones thoughts?
Thanks
Goldie
Old Jun 18, 2019 | 04:14 PM
DonnieM's Avatar
DonnieM
Welcome to the Forum!
You left out what year and bike we are working on
Old Jun 18, 2019 | 04:19 PM
GoldieG's Avatar
GoldieG
1st Gear
Oops!
its a 2019 forty eight 😁
Old Jun 18, 2019 | 04:59 PM
MyFavRk's Avatar
MyFavRk
I put in a set of crusher mellow baffles in a set of cvo mufflers , after that I gave V&H a call and explained to them how I modified them to fit . They recommended me the perfect map for my set up and to do an auto tune after that . Bike runs better than awesome now .
Since your using an FP3 I would work with V&H in getting it set up just right . Calling them would be better than an email . Brian from V&H may chime in and give his thoughts also .
Bet your set up sounds wicked !!
Old Jun 19, 2019 | 12:03 AM
GoldieG's Avatar
GoldieG
1st Gear
Thanks guys! I’ll speak ton V&H about the base map 👌 glad it sounds like it might work 😄😄
Old Jun 19, 2019 | 07:44 AM
T^2's Avatar
T^2
Drag pipes... Hacks... Ugghh...
How to best deal with drag pipes... See the 4:35/10:42 mark in the following video...
To understand why... watch the rest of the video... Also... maybe peruse these quick reads...
http://www.zggtr.org/index.php?topic=960.0
http://www.epi-eng.com/piston_engine...technology.htm
https://www.hdforums.com/forum/sport...l#post17075742
In those links you'll also find material that speaks to the "back pressure" myth.
After reading all that... You might come to the conclusion that proper exhaust systems are not just some pipes bent to look and sound good. There is a reason that the word "system" is used in the term Exhaust System and that system is part of a larger system. Properly designed and executed - that system can produce "JOY". Poorly (likely ignorantly) executed it can produce "****". Sure you can probably mitigate the **** to some degree tweaking/tuning, but just guessing... the likely outcome is just a lesser degree of ****.
I haven't seen any tuning attempts/dyno results on those LAF drag pipes... But just based on appearances, my first instinct would be to refer again to the 4:35/10:42 mark in the above video.
Old Jun 19, 2019 | 09:13 AM
GoldieG's Avatar
GoldieG
1st Gear
Cheers.... I think
I think its the mitigating **** bits that im interested in. Im not looking for cuting edge perfomance, I sold a gsxr to buy my harley.........
but anything that i can do to assist is what im going for without causing any longer term damage
Old Jun 19, 2019 | 03:41 PM
GarageJockey's Avatar
GarageJockey
I ran the LAF's for a couple years and changing them now because they drag after i lowered the bike, otherwise I was happy with them. I tuned it with a powervision and lollipops in the pipes. When i first put them on the bike it was a noticeable performance upgrade from the SEII slip-ons and stage 1 HD tune. They are not too noisy at an idle and low rpm cruising but can be very loud when you want to be.
Old Jun 19, 2019 | 03:46 PM
GoldieG's Avatar
GoldieG
1st Gear
Good to hear 👍 I’ve got the pipes, wrapped, baffles in (although I may modify the baffles into more lolly pop style items), air intake and FP3 lined up ready for the weekend 🤭
Scooter68
Jun 11, 2016 01:32 AM
bigskyroadglide
Jun 1, 2015 08:43 AM
fathom2636
Engine Mechanical Topics
Aug 11, 2011 04:12 PM
chopper103in
Jul 19, 2010 07:19 AM
Saikia
Exhaust System Topics
Mar 25, 2008 07:34 AM
