Slack in throttle
Old Jul 18, 2019 | 08:59 AM
lowriderr9's Avatar
lowriderr9
Default Slack in throttle
2007 ultra classic. I have what feels like slack in my throttle cable. I have to turn the grip a little before I feel pressure. Should I leave it alone or can it be adjusted out?
Old Jul 18, 2019 | 09:25 AM
Labrador's Avatar
Labrador
You can adjust the cable. But, I think that you should also inspect the cable as the slack may indicate that your cable has stretched and may break/snap any time soon.
Old Jul 18, 2019 | 10:33 AM
ohioflhs's Avatar
ohioflhs
They need a little slack or when you turn the handlebars, it will get tight and accelerate by itself. There is a procedure that tells you how to set it properly in the maint manual.
Old Jul 18, 2019 | 12:01 PM
kngpn's Avatar
kngpn
how much slack? there should be a small amount.
Old Jul 18, 2019 | 02:09 PM
lowriderr9's Avatar
lowriderr9
Default Slack in cable
I will read up on it. I just think it may have a little too much. Thanks
Old Jul 19, 2019 | 05:32 AM
ohioflhs's Avatar
ohioflhs
Could be too much. Just make sure after the adjustment you can turn the handlebars from stop to stop without affecting idle speed.
Old Jul 19, 2019 | 05:52 AM
Jackie Paper's Avatar
Jackie Paper
Both cables should have a slight amount of play at throttle body. Note this should be correct at both locks of the handlebars. So you may have a little at grip.
Follow service manual to check it. Depending on miles, those two little clips cups the ***** on end of cable sit in may have worn a little.
Old Jul 19, 2019 | 08:18 AM
merlin 2's Avatar
merlin 2
i think there is a sticky some where on how to adjust that.....
Shark.Glide
Aug 18, 2015 07:13 PM
sp9997
Apr 22, 2013 06:31 PM
bigdano
Sep 2, 2011 09:35 AM
Big Hog
Exhaust System Topics
Jan 24, 2010 09:20 PM
Whiffleboy
General Topics/Tech Tips
May 8, 2006 06:16 PM
