Dont Use a Pressure Washer to clean your motorcycle!
Old Oct 29, 2019 | 08:40 AM
barneyboy's Avatar
barneyboy
Originally Posted by Buster217
Why use a blower to dry it? Just go for a ride. It has the added benefit that the heat drives the moisture out of the nooks and crannies on the engine and transmission.
Keep an eye on the temps. Sunny and 30°F, 80 mph blow dry, missed my exit when the throttle cables froze up.
Old Oct 29, 2019 | 08:43 AM
Labrador's Avatar
Labrador
Originally Posted by NORTY FLATZ
Yeah, Armor-all is a no-no.
Nothing goes on yer tires. Ever.
I sure learned that Armor All on a bike is not a good idea. I once applied it to the foot boards and everything else black on the bike. As you can imagine, the Armor All got onto the bottom of my boots and at the first stop I put my feet down and my leg slid. Had to go back home and take that crap off. Never again.
Old Oct 29, 2019 | 08:48 AM
SirHarley's Avatar
SirHarley
Originally Posted by Bluesrider.df
"Hey y'all, watch this."
In the back of my head, I always wondered if that was possible. I guess now I know...lol! And to the earlier poster who said "Armor All is making his tires dependent ". Is that stuff like crack? I have never walked into the garage and heard my tires saying "MAN! You gotta give me a fix Man!" "I'm jones-ing bad!" lol! Do they have an Armour All clinic for withdrawal from it? I'd like to get the rest of the mileage out of my tires if I can.
Anyways, I just spray it on a rag and wipe it down by hand. I have a friend who put it on his seat just before a ride, and wiped out at the first intersection he turned into. It was a smooth Jap bike seat. I have never experienced any tire problems from using Armour All or another equivalent. I don't leave it dripping wet either though,....
Ride Hard, Ride On...!
Old Oct 29, 2019 | 08:58 AM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by roussfam
I wish someone would post how to properly inflate tires. I've probably been doing that wrong as well
Roni, Glyder or BBM could probably help you there....
Old Oct 29, 2019 | 09:02 AM
SirHarley's Avatar
SirHarley
Originally Posted by kel03
Front tire first.........
And rotate your wheel so that the valve is at he 12:00 O'clock position before you fill.. So then the Air you add will mix better with the Air already in the tire. Then ride slowly at first to mix it up properly! lol!
Old Oct 29, 2019 | 09:12 AM
hvacgaspiping
Originally Posted by 470004
Now that`s what I call a "Clusterflush".
Old Oct 29, 2019 | 09:27 AM
ChopSticks's Avatar
ChopSticks
Pressure washed one of the bikes that only get ridden during the summer/weekend literally last Saturday. OP is somewhat correct, you have to be cautious of the wheel bearings and any gasket areas as some of the pressures can take the black right off a kettle. Other than that the water shouldn't be able to penetrate solid metal
Old Oct 29, 2019 | 12:34 PM
rizzo's Avatar
rizzo
Did this thread get cleared approved by one of the resident subject matter experts ? It may be in violation.....
Old Oct 29, 2019 | 12:45 PM
sailmotion's Avatar
sailmotion
Does that make any sense to you? If you try filling your tires with the valve at 12 o'clock [BTW, you don't mention a.m. or p.m.], then all the air will spill on the ground before entering the tire. Obviously, you need to be at 6 [a.m. or p.m.] so the air can flow into the tire.
Old Oct 29, 2019 | 01:11 PM
smitty901's Avatar
smitty901
49 years of washing my bikes and now you tell me. Was not a problem until now.
