Another Tender bites the Dust
Old Dec 3, 2019 | 09:21 PM
hardheaded's Avatar
hardheaded
Default Another Tender bites the Dust
My 4th tender has bit the dust in 9 years. I do have 8 plugged in all the time, but i have to wonder why they don't last longer. Deltran takes care of you even if out of warrenty though. Not free but cheaper than buying another new one.
Old Dec 3, 2019 | 09:32 PM
CGLTD's Avatar
CGLTD
I've been using the same one for 10 years. Only bought this one because I dropped the older one a few too many times.
Old Dec 3, 2019 | 09:40 PM
TriGeezer's Avatar
TriGeezer
I’ve got the same Deltran Battery Tender that I’ve used for 7 years.
Old Dec 3, 2019 | 10:02 PM
user 7172984932's Avatar
user 7172984932
I only have 1 battery. I replaced mine after 10 years thinking it wasn’t charging. Green light never came on.
Turned out is was by pig tail cable from battery to tender cable. Kept it as a backup.
Old Dec 3, 2019 | 10:24 PM
AussieDog's Avatar
AussieDog
My Deltran battery tender is now in its 6th winter season. Seems to work fine. WTF?
Old Dec 3, 2019 | 10:39 PM
son of the hounds's Avatar
son of the hounds
Deltrans battery tender juniors since 2005. Same unit for the bike and one on the sports car bought 2009. Also have 6 volt version for vintage bike. Check your ground and your voltage.
One thing I do as part of the winterizing is i use my full service battery charger to make sure all batteries are at full charge before placing them on the tender for the winter.
If your deltrans are failing, and it is not caused by your ground or voltage, or a weak battery to begin with, then maybe older ones are better quality.
mine get warm, but not hot when charging. Something may be causing yours to over heat.
Old Dec 3, 2019 | 11:20 PM
2whlr4life's Avatar
2whlr4life
Arrow
Sorry about your bad luck, I can't explain it.
15+ years on my original Battery Tender Jr.
Old Dec 3, 2019 | 11:30 PM
RKDavid's Avatar
RKDavid
Thank you, (sarcasm) I always thought mine would last forever, now with my OCD, I'll be checking it weekly for the rest of the winter..
Old Dec 4, 2019 | 12:07 AM
martin10's Avatar
martin10
I have had 2 fail over the years. In both cases the green led would be lit showing a full charge. But in fact it wasn't charging the battery. They both lasted several years. But thinking the battery was charged when it wasn't sucks.
Old Dec 4, 2019 | 06:12 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I have two, one is over 15 years old, the other is about 10 years old. Never had an issue with either one of them.
