New BS from the MOCo
Old May 10, 2020 | 11:05 AM
  #61
bowelder's Avatar
bowelder
Originally Posted by dawg
Mind you this is not based on dealer cost, rather consumer cost so it would be cheaper for them anyway. Nonetheless, tube is $4. Primary cover gasket is about $30 (which technically could be reused, but let’s replace for this scenario as they would do it). 38 oz of primary fluid (dealer uses amount out of 55 gal drum so there’s a cost differential there as well, but let’s say $5 or so). O-ring and derby seal (kit) is $5. Labor is only 1/2 hr to install so if using a $90/hr shop rate you would be at $45. Add it all up (again based on consumer cost and not dealer cost) and you’re at about $100. Dealer cost would probably bring it back down to about $75. So to answer your question, it costs about $75 to do the fix.
I was told by the service manager it would be about $ 300.00 , our dealers in New Jersey charge a lot more for labor.
Old May 10, 2020 | 11:09 AM
  #62
bowelder's Avatar
bowelder
Originally Posted by Germansheperd
It is because you FINANCED the bike through Eaglemark and you FINANCED the service contract through Eaglemark thats why it is listed on the contract. CNA is Harley’s service contract. The reason they do that is if you were to cancel the service contract early the refund goes back to Eaglemark and then comes off of your loan.
There is NO BS here at all. You are uninformed.
I realize now that is the case, but thank you for pointing it out.
Old May 10, 2020 | 11:14 AM
  #63
dawg's Avatar
dawg
Originally Posted by highwayman50
Not to hijack a thread but, may I ask where you live? I only ask because dealers in my area Detroit/Toledo haven't been at 90$ a hour for years. A buck twenty is about the best you can find these days.
Yea, my bad. Just checked the local dealer website and see $125/hr. Last time I remembered it was about $85. In any event, should be 1/2 hr labor so your still around $100/just under for the cost.
Old May 10, 2020 | 11:17 AM
  #64
dawg's Avatar
dawg
Technically, it would most likely be that anywhere. They won’t charge for just the tube, they’ll do it with the kit which is, IIRC around $45-50 which includes the gaskets. Then they’ll charge much more for replacement fluid than they should, then they’ll charge for “shop supplies,” and lastly they’ll charge at least 1 hr labor when it only takes 1/2 hr. Hence, if one can do it themselves, it’s about $20 tops for the hose and replacement fluid.
Old May 10, 2020 | 12:34 PM
  #65
GOV5's Avatar
GOV5
Originally Posted by skratch
there is no evidence that any bike has 'blown' up over transmission oil transfer. the oil will transfer to a point, and then stop. it will not completely empty out the transmission. is it ideal? no, of course not. but you should catch it during your periodic checks (you do do those right?) so it isn't like you're running your transmission dry for tens of thousands of miles.
you've already got a 2 year, unlimited mileage 'bumper to bumper' warranty, in writing, from the moco. some people may make it to 100,000 miles by then. most won't. i don't know of any mfg, car or motorcycle that will give you an unlimited time, 100,000 mile warranty. my truck came with a 5 year, 60,000 mile warranty and i burned through that in less than 3 years.
most of the problems that you hear of are not from the moco, but the dealer. personally, i've never had any warranty issues from my dealer. course, i've had very few issues that needed to be taken care of under warranty.
Well I'm not a mechanic so I don't know how to answer you about "it won't transfer enough to do any harm, or blow up the engine". I'll take your word for it, but if it's below what the MFG calls for, that can't be a good running situation. And if it isn't a alarming situation, then what has been all the fuss about on the forums for 2 years then? In other words, it's a Bad situation!
And a few years back, there WAS an auto mfg, don't remember who at this time, that had a 10 yr, 100,000 warranty. You look it up, I will not do YOUR research for you. You're a big boy...find it yourself!
And I can tell by your post, YOU are one of the customers that has failed to hold Harley accountable for anything, so YOU are one of the reasons the guy is having the problem in the first place. Keep being the Harley Fanboy, and watch what you keep getting...a poorly manufactured, design flawed bike with no Company OR Dealer backup when there is a problem. Your kind is a dying breed, and it can't come fast enough. It's the main reason for Harley's continued decline in sales and profits.
Thank goodness Zeitz is finally recognizing this and vows to turn around that kind of attitude from Harley internally. There IS hope for the future, but man, he has a HUGE task in front of him. Harley has lost customers they may never regain again. Time and Zietz's efforts will tell.
Old May 10, 2020 | 12:42 PM
  #66
dawg's Avatar
dawg
Well, there you have it. Skratch is a fanboy and is the reason my bike transferred. Nice going, skratch. If it starts sumping, I’m coming after your ***!
Old May 10, 2020 | 02:01 PM
  #67
skratch's Avatar
skratch
i don't have to research. your earlier post didn't say anything about time, just mileage. now you're throwing time in there as well. not my fault you keep changing the parameters.
i'm a reason he's having problems? because i've never had an issue with getting any warranty work done? in the 18 years/9 bikes that i've purchased, none have ever left me stranded, and i've only had to have 2 or 3 warranty items repaired.... explain to me how that is a problem?
i'm not a 'fanboy', but i've never had a problem that i've had to go all don quixote on either. and i stand by my original statement, it isn't the moco so much as it is his dealer. if you have a good dealer, you are going to have a better experience than if you have a bad dealer.
lol. come on down to la, if it doesn't sump by the time you get here, you're good. i'll buy the beer.
Old May 10, 2020 | 07:32 PM
  #68
Bone Doc's Avatar
Bone Doc
First of all, I hate that you had a problem with your bike. And I hate that you have gotten some snarky replies. You don't deserve either of the two.
And to the poster that ridiculed you because the bike has only 2000 miles and called it a Garage Queen, his reply should have chastised the MocO for selling you a bike that had A PROBLEM at ONLY 2000 miles!
As for telling you to calm down when talking to people, yes, that's OK advise, but it's VERY HARD to put into practice when you have an issue that COULD HAVE blown up your bike if left unfixed and you hadn't caught it in time. And, folks from the Harley dealer and the ESP are telling you the "FIX" is on YOUR DIME. HELL, I'd be raising hell too!
The dealer should fix it for you and shut up. They also should have called ALL their customers with the new M8 models and told them to come on for the fix, since it was a service bulletin from the MoCo. Who's to blame then? Well, it's a design flaw. It's the Manufacturer that designed and built the bike. THEY are to blame! Now, I don't know what's involved with fixing it...the $4 cost of the vent isn't the issue I'm sure..it's the labor to do the job, and all that's involved with that. What does the FIX actually cost? Are we talking hundreds, thousands...what?
You need to know that cost, because that will tell you a lot about why you are getting pushback on who will be paying for the FIX.
I know the dealer shouldn't be saddled with fixing design flaws by the MOCO, and they aren't financially equipped to do that anyway. If Harley puts out a bike series with well-known, and well-acknowledged issues, they should be made to fix those issues. PERIOD! I would call the MOCO direct and ask for a Customer satisfaction repair on their dime. My bet is that they will issue it for you.
Now hear comes what most here at this place don't want to hear: Who REALLY is to blame? Well my friend, it's ALL of us. WE have actually "trained" Harley to treat us like YOU have been treated in your case. Over the years, we have let them get away with design flaws that we paid for out of our own pockets, rather than forcing them to fix them at THEIR cost. Heck, they got away with it for so long they kept producing models with the SAME flaws, rather than spending the research money to fix the issue, because they knew we would pay the dealer to get it fixed. SO it was a WIN for the MOCO, and a WIN for the dealer too because the dealer got more shop money BECAUSE Harley put out a poorly made bike! If it wasn't true, you'd swear this was a conspiracy theory. THis scenario has been going on since AMF days too.
Well, it's time to FORCE the MOCO to act differently. Don't buy their motorcycles for a while. They will change things, I GUARANTEE THAT! For those of you that will buy them, at least have the guts to get in writing, with a form you brought with you, that they will give you a "bumper to bumper" warranty, from the MOCO, that will take care of ANYTHING that goes wrong with the bike for 100,000 miles, with no deductible! NO $50 co-pay jazz either. And with a 2 day shop turnaround time. Face it fans, they aren't going to change on their own. WE need to force this change upon them, or QUIT YOUR BITCHIN' .
Someone needs to pinch GOV5 and bring him back to reality. He's living in a fantasy world.
Old May 10, 2020 | 07:54 PM
  #69
NORTY FLATZ's Avatar
NORTY FLATZ
As common as the "oil transfer" issue has been, you'd think the MOCO would have discovered & addressed this during their "alpha testing" of their power train mules. It HAD to have happened to their test fleet. Unless the bean counters took a calculated risk, figuring most riders won't ride their bikes very much. And that they'll begin to transfer AFTER the factory warranty is history. This helps their dealership network with repairs to customer bikes, at the customer expense. I almost wonder if the MOCO had planned this event to happen to a certain number of bikes (or ALL of them...) It STILL doesn't seem like the MOCO has fixed the problem at the factory level. This tells me, either the MOCO doesn't care about their perceived quality, or there's an agreement somewhere, between the MOCO and the dealership network, to screw the end user that rides their bikes....
How long have we heard about this now? About 2 weeks after the first M8's went out?
"Planned obsolescence?"
Don't get me started on the friggen bearings these bikes have...
Old May 10, 2020 | 08:01 PM
  #70
golfblues's Avatar
golfblues
Wow, thank God HD Forum members are in the minority of HD ownership. The vast majority of HD owners have had excellent experiences with their bikes. And they don't come here and whine about every little bitch they have with HD. Grow up and figure out how to deal with a company when you have a problem. It's not that dramatic.
