remove cb antenna female stud
Old Jun 29, 2020 | 05:40 PM
matthew6279's Avatar
matthew6279
Default remove cb antenna female stud
2020 flhtk. How do you remove the female threaded portion from the tour pack for the cb? I want the plugs to match but can't figure out how to remove the female portion of the cb antenna mount.
Old Jun 29, 2020 | 06:15 PM
Ssitruc's Avatar
Ssitruc
1st, the AM/FM is opposite of the CB, so with the AM/FM don't so this...
For the 2016s the CB one is 3 pieces (46, 47,48), the stud sticking out (#48) will unscrew from #46 on the CB one, if its not too corroded. Then the hole plug/cover is #27, part #12100023.
On the AM/FM antenna the base is 2 pieces (50 & 51), the stud that the antenna screws onto is part of #50 and it won't screw out. You have to unscrew #51 out from inside the tour pack then all of #50 lifts out.
I found out the easy way... I broke the AM/FM one off...
For the 2020s I couldn't find the diagram that shows #48, but all the other pieces are there and show the same part numbers as below.
On mine, a 2016, I took #48 off and put the #27 plug in it, and on the AM/FM I took the base completely out (50 & 51) and stuck a #46 in there too and used the #27 plug on that side too... I think the little plug (#27) needed the part #46 to kind of "click into" to hold in place so it would stay put, if I remember right.
Old Jun 29, 2020 | 06:49 PM
matthew6279
Got it off thank you.
Texcuda
2014-2024 Touring Models
Jun 19, 2020 08:55 AM
Greg Di
20
Sep 25, 2017 08:46 PM
Billf
Nov 5, 2012 09:41 PM
FINALEFFORT
Sep 26, 2012 10:57 PM
Mike2361
Nov 28, 2006 02:57 PM
