External Seat Pads?
What part of Texas are you in? If you are anywhere close I'll let you try a ventilator.
Loved it right from the get-go
bought an Airhawk a few weeks later just to see if it was better
I hated the Airhawk at first (it took forever before I finally got the air amount dialed in just right for me)
Once that accomplished, I like it plenty good too
I really can't say one is better than the other as far as comfort (both are good) or being hot in summer (both are too)
the only ding I give the Airhawk, it has to be strapped to seat or it falls off when I dismount .
also just slight breeze will blow if off the bike when you're not on it.
The gelpad is much heavier and stays put without straps when I get off and on
and takes a 20+ MPH gust to blow it off the bike
..L.T.A.
Before I had it, at about 120-130 miles my butt was killing me. Tailbone was sore and the 'soft tissues' getting numb and aching.
Put the Airhawk on and did 200 miles last Saturday and no pain, no numbing, no aches. And I haven't really spent enough time to really dial in the air pressure. So chances are I get get it even more comfortable.
So color me a believer. And hundreds of $ cheaper than a new seat. Yes, it requires straps to secure it, but once it's installed, well, it's good to go. Haven't touched it since I put it on.
Just my $.02,
Michael
I had one of the original Neoprene Air Hawk pads and loved it after I got the amount of air right. It finally walked away and I bought a replacement which is now made of PU material. I still haven't got it dialed in just quite right, it works ok but I liked the Neoprene much better.
I have a large aftermarket seat that I cut way down (as I'm short 5'7") .....then installed a gel pad in on top of the cut down foam, THEN I installed the bladder only portion of a blood pressure cuff on top of the gel. It's just a large, flat (when deflated) air bladder with a bulb to pump it up and a valve to release. Kinda like this:
BP Cuff bladder
I have some ultra thin foam padding in there between layers. I did that as I read that seat gel can get super hot in the summer sun.
I like the gel. I find it makes a noticeable, but relatively minor difference. It was a $90 sheet of the saddlemen gel. Again, it's UNDER the cover (not on top)
At times I will pump up the bladder, and find hour to hour adjusting the air pressure up or down, just kinda "depending"
Last year after the seat was cut down, but before installing the gel I had tried the bladder sittin on top of the seat for a whole summer and it worked "OK", so the 2nd time I took my seat apart, I installed it permanently INSIDE the seat. I didn't get it oriented
perfectly, (sits a smidge too far forward, so the 3rd time I have the seat apart, I'll push it more to the back....near the backrest "area" of my aftermarket seat for more support. (nearer to the small of my back/tailbone_)
I will say, it's an interesting sensation pumping yourself up on an inch of air....but I don't find it's comfortable over the long haul. After a while you can't tell you're sitting on an air bubble (maybe my butt is asleep?) and it just feels hard-ish. If you make the bubble too big, it'll frig up your balance during turns...especially slow speed manoevers. Also, for shorter riders like me....if you have it pumped way up and forget, and plant your feet at a stop sign, sometimes the road is not there, so I always remember to reach back and let air out if I am coming into a town.
My post kinda rambled on there..
I think I'll end it here.
Hope you fellas found it of some use. I really should've started my own thread bestowing the good/bad and the ugly of doing this to a seat. Maybe next summer.
ETA:
Thank you all for the replies and suggestions, as I've stated before this whole bagger thing is new to me and y'all are making it a lot easier to learn
