Hit it or Lay it Down??
Old Dec 23, 2020 | 07:55 PM
  #81
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Originally Posted by son of the hounds
I'm not saying you are incorrect, but your analysis is flawed. You have no idea what would have happened in you emergency braked and lost 30 or more mph before impact. Your motorcycle was under the other vehicle because you laid it down. You have no idea how much you might have mitigated your injuries had you lost as much speed as possible and remained above the vehicle. You quote the officers, but I doubt if they would have laid it down.
It's your memory, your story so I don't doubt it. I just believe you only had that one outcome and there might have been a better one. I do agree, most riders repeat mistakes as well as good responses. Only you know if it could have been different, maybe not. Maybe it was fate.
There is always the chance that trying something else may have been better but at that split second in time I felt that was the best option. Car was coming straight at me with no where to go and if the officers distance was correct there was only 30' to do something. I had been riding for about 35 years at that point in time so I had more than a few miles under my belt. I cannot remember how far it was when I first saw the car but I know it didn't look like very much distance and I could see no other option. Let's assume the cars were moving at 40 mph which was the posted speed limit and I was about there too. That means we had a closing speed of 80 mph and 30' to do something!
I'm hear to talk about it, so it wasn't the worst option but I can tell you I never want to have to make that decision again!
Old Dec 23, 2020 | 08:34 PM
  #82
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Originally Posted by Falco144
You didn't have time to brake but had time to "lay it down"?
LEARN how to f-ing brake! I doesn't matter how many years of riding experience one have, proper braking is the most important skill rider can learn.
In my opinion and 40+ years of riding and racing, 90% of riders do not know how to properly brake and what it takes to "lock up" the brakes. This percentage is higher for cruiser types because many riders are afraid of using the front brakes.
With linked braking systems and ABS there is absolutely no reason to be afraid! Squeeze that level!
Laying it down is an excuse and never acceptable! It is the biggest myth!
While you may want to believe that, I have to disagree. You put yourself in the position I was stuck in, 80 mph closing speed and 30' and you want to take a head on hit, sitting on the bike, with your right hand squeezing the front brake lever and your right foot pushing the rear brake pedal down! Then the hit occurs and your going to get slammed straight forward and everything below the waste slams into the tank and dash and since you were pushing downward and forward with your right leg, it gets mangled on the way forward. Once your body hopefully gets off and over the front of the bike your going to be on to the hood of the car heading for the windshield and beyond. There was no good choice, and I will never know what doing something other than laying it down could have done, but in my split second decision I got off the bike and cleared the hood but didn't clear the top of the windshield. That's what busted my right-side up and I ended up with a little road rash on my left arm about 3" long and 1" wide. Helmet did its job, boots and gloves were a little worse off. I had no jacket on as it was a 85 deg. day and I was out in the mountains heading back home from a day of riding. I am not here trying to make anyone's mind up for them but in certain cases IMHO Laying a bike down is the best choice in a bad situation.
Old Dec 24, 2020 | 01:11 AM
  #83
White Ice's Avatar
White Ice
Compare the brake pads on the side of your gas tank and/or saddle bags to the brake pads mounted on your wheels.....which set has the best chance of stopping your bike???
Old Dec 24, 2020 | 01:56 AM
  #84
Highwaymans's Avatar
Highwaymans
You can be pretty much assured most here in a true oh **** emergency situation wouldnt react either way knowingly... They'd freeze and hit it and if they did lay it down itd be from poor braking and putting it down (of course the story is, I had to lay it down)
Old Dec 24, 2020 | 06:13 AM
  #85
CaffeineBuzz's Avatar
CaffeineBuzz
look... I’ll install brake pads on my tank and bags when you make the streets out of rotor material
Old Dec 24, 2020 | 07:46 AM
  #86
Durango Dave's Avatar
Durango Dave
This is why you need to think about these situations before they happen. This is true of motorcycles and self defense and any other emergency situation. If dire situation X happens know in advance what you should do.
For that reason each of us should know if someone pulls out in front of you NEVER ever ever, under any circumstances whatsoever should you ever think of laying it down. NEVER! I am NOT saying it's never advantageous to lay it down. I am saying it is so rare that you should never say "in the last few milliseconds before a crash I will analyse the situation and decide if it's best to lay it down" NO NO NO! Prepare to do what is best 999 times out of 1000. Trust your brakes and steering.
Also practice these emergency manoeuvres. Even if you have ABS practice emergency braking. Once a week or at least once a month check to make sure no one is behind you and slam on the brakes. That will take time to be good at it. The first few times be very careful. Later you can brake as if your life depends on it. With practice you can stop better than ABS. At first let your ABS kick in. Pay attention. Is ABS kicking in for the front AND the rear? Even with ABS I think a lot of people won't stop as fast as the motorcycle is capable.
Old Dec 24, 2020 | 07:50 AM
  #87
1999 flstf's Avatar
1999 flstf
i have never "layed" a bike down at any speed had the rear tire kick out from under me came in a little to hot in a turn that had a painted crosswalk. thought it was a smart idea to take the brand new dirt bike out for a test ride in the snow in a tee shirt went down around 25mph slid on ice. i can tell you ice burn is real.
i got tboned by a car doing about the same, i was sitting i traffic all i still remember screeching tires and the split second i had all i could do was pick my left leg up, and that was completely a reflex.
Old Dec 24, 2020 | 03:38 PM
  #88
not a sock's Avatar
not a sock
I've posted this before so I won't do it all again........
......several years ago, wifey and I were on an '08 Heritage Classic.
NO ABS, just my skills to guard us.
Was I going too fast thru an intersection; sure was.
Should the third vehicle have stopped at the stop sign; should have.
I was trying to avoid his truck bed and NOT lock my rear wheel.
Pulling the front brake as hard as possible and feathering the rear, I
missed him by inches............
Then, at that time, the rearend started flipping back and forth. I'm out of one
problem into another.
I got my wits about me and let off the rear brake when the rearend was straight.
On down the road we went.
Was it ever close!!
Did I EVER think of laying the bike down to avoid hitting the truck; NEVER!!
I was confident in my skills and avoided injury to me, wifey and bike.
As riders, are we going to be able to avoid every situation? Never.
Do we ride defensively? Yes.
I can't say that each situation is the same because it isn't.
We should have a plan to expect the unexpected................
Old Dec 25, 2020 | 05:45 AM
  #89
skootchnc's Avatar
skootchnc
Then you understand brakes stopping you in a timely fashion wasn't always an option.
I understand careless behavior from one party, or perhaps both... reduces ones reaction time.
I've yet to have anyone show me (with evidence) that hard braking does not lower the impact speed, and sliding out of control somehow does.
And yes.... I've heard of Motor Officers, and Military training, where riders are taught to "lay the bike down"...
It is MY understanding, such action, is less "safely stopping" a motorcycle, and more about using the motorcycle as a shield.... not that I'd feel particularly safe, using the fuel tank to stop incoming rounds
Old Dec 25, 2020 | 06:31 AM
  #90
Bass Player's Avatar
Bass Player
I get what you are saying. I started on BSAs and Triumphs in the late 60s early 70s. Stopping wasn't the high point for either. I was a bunch younger then and bullet proof. So saying I rode "smart", well you know. In time we all should learn (?) to ride smarter. But we can't avoid someone else's stupid.
