Finding the Horn Button
Old Jan 18, 2021 | 08:43 AM
  #41
CaffeineBuzz's Avatar
CaffeineBuzz
my HD owners manual instructs me to beep my horn every time I change lanes....lol
only time I've ever used it was when I accidentally hit it when going for the turn signal, which I don't use as often as I should, so I pretty much suck at finding that too.....evidence being that sometimes when i go to hit the turn signal, i hit the horn
Old Jan 18, 2021 | 08:47 AM
  #42
GBHH's Avatar
GBHH
I find one of the biggest handicap's of getting older is all the words replaced by symbols.
Sometimes I'll get out a magnifier and then still can't figure what the symbol means.
A generational problem if there ever was one.
Fond memories of English words on buttons.
Old Jan 18, 2021 | 09:14 AM
  #43
BuzzCap7's Avatar
BuzzCap7
Originally Posted by Kenny94945
OP is not alone.
I too find honking the horn futile.
Better to concentrate on braking, swerving and acceleration instead of beeping a horn.
FWIW...many Harley have custom exhausts.... just rev the motor to make your presence known.
I have Rineharts. I do the REV thing when the chap in front of me does not see the turned green. Works well.
Old Jan 18, 2021 | 09:26 AM
  #44
RK_Classic's Avatar
RK_Classic
I routed my horn button in the *** crack of my seat, so when up pucker up during those "OH ****" moments, the horn blows.
rk classic.
Old Jan 18, 2021 | 10:52 AM
  #45
RHPAW's Avatar
RHPAW
Doesn't it already make a noise without the button?
Old Jan 18, 2021 | 11:45 AM
  #46
BelchFire's Avatar
BelchFire
rk classic.
OK, I actually laughed out loud about that one.
OP, this is a great idea and one that I'll probably be doing. I may even do it on the kill switch side, because I didn't get a red kill switch. (Claiming my cross thread points too!)
But let's politely put things in perspective. If I need to tap the horn, I can take the split second to look for it. If I don't have a split second to look for it, tapping the horn, chowing down on the horn, giving them an earful of left turn signal, high beams or any combination of the above won't remedy any situation that's about to happen to me.
Oh, and thank you for your service; YOU are what makes America great!
Old Jan 18, 2021 | 12:40 PM
  #47
rjg883c's Avatar
rjg883c
I've found "beeping a horn" can usually prevent a need for "braking, swerving and acceleration". At least in cases where I can anticipate a cage driver's action.
Of course the "beeping a horn" must be done before "braking, swerving and acceleration" are actually needed.
Sort of like putting on a coat before it is actually needed i.e. before going outside.
Old Jan 18, 2021 | 01:06 PM
  #48
RHPAW's Avatar
RHPAW
When I had a fairing on my Shovelhead, I had two dummy switches on there.
One said "Eject Passenger"
The other one was labeled "Rocket Launcher"
If either one had actually worked, I would probably still be in jail.
Old Jan 18, 2021 | 01:22 PM
  #49
scoriden's Avatar
scoriden
I scored a left-hand control switch lower from a Dyna Defender. You can see the extra button; my thumb falls nicely to it. On a Defender, It was originally for a siren and was red, I painted it black. Now both switches will beep the horn.
I also like the OPs added button, If I hadn’t done what I did I would probably try his solution.
Old Jan 19, 2021 | 03:25 PM
  #50
Burbur2's Avatar
Burbur2
I would really like to see some of these loud horns and how you guys installed it on the bike. I always wanted one never had a chance to install one yet.
