88 electra glide classic
Old Jul 31, 2007 | 06:53 PM
red rigid's Avatar
red rigid
Stage II
Default 88 electra glide classic
i am having a problem with the tach & radio on a 88 electra glide classic.the tach goes to 5 or 6 grand when the engine is still at 2 or 3 grand, and the radio pops & crackles. the volume control stops working & the screen on the radio goes off. if you turn the key off & back on, everthings fine until you start the engine again & run the bike.the charging system was overcharging so the voltage regulater was replaced.all grounds & hot wires seem to be good.does anybody have any ideas before i spend a bunch of time tracing down the wiring?
Old Jul 31, 2007 | 07:33 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Default RE: 88 electra glide classic
I had a similar problem with an 02 Superglide. I tried everything I could think of, turned out to be a cracked positive cable coming from the battery.
Old Jul 31, 2007 | 09:25 PM
BigJfxdwg's Avatar
BigJfxdwg
Might be a ground, I had a similar problem with the radio/8-track player on my KZ1000, turned out to be a ground. Good luck.
If all else fails and you want to sell that POS for a couple grand give me a call.
fiddledicksr
Audio Systems
30
Mar 28, 2022 10:49 AM
bobgv
Audio Systems
Oct 15, 2015 12:53 PM
davidw221
Audio Systems
Aug 21, 2013 05:11 PM
Arizona Mike
Sep 18, 2012 09:31 PM
perch73
Jun 19, 2009 07:09 PM
