Tips on buying a used S&S motor?
Old Feb 16, 2021 | 08:20 PM
RedTailChop's Avatar
RedTailChop
Default Tips on buying a used S&S motor?
I bought a fxr project and I spotted a 100" S&S for cheap. I've never purchased a motor by itself. What do I look for to make sure I'm not getting ripped off?
Old Feb 16, 2021 | 09:39 PM
chopper_man's Avatar
chopper_man
Title and or MCO (Manuafacturers Certificate of Origin) is a must.
Old Feb 17, 2021 | 07:17 AM
RedTailChop
He does have the MCO.
Old Feb 17, 2021 | 07:26 AM
RHPAW's Avatar
RHPAW
Make sure it will fit your application.
FXR primaries are different.
Old Feb 17, 2021 | 07:49 AM
1999 flstf's Avatar
1999 flstf
i would want to know where the rest of the bike is. did he swap it out for another motor. what's the mileage on it,do they have any service records? what happens when you install it and the bearings are shot or other internal problems show up. or are you buying it to rebuild it?
proof of ownership would be a must for me
Old Feb 17, 2021 | 07:53 AM
1999 flstf's Avatar
1999 flstf
how cheap is this motor. unless it's a friend remember if it sounds too good to be true, usually is. hell i've had "friends" stick it to me before
Old Feb 17, 2021 | 09:42 AM
RedTailChop
Originally Posted by 1999 flstf
how cheap is this motor. Unless it's a friend remember if it sounds too good to be true, usually is. Hell i've had "friends" stick it to me before
1,800
Old Feb 17, 2021 | 09:45 AM
Ray on the drums's Avatar
Ray on the drums
First step...I'd meet the guy, listen to him and judge the book by the cover.
Old Feb 17, 2021 | 10:27 AM
Srrmc's Avatar
Srrmc
I had an S&S 100" square motor. The first one walked a wrist pin keeper out and then the wrist pin worked its way out into the cylinder wall. they covered it under warranty. i could contact S&S and give them the ID # off of the motor and ask them if they have any issues with this particular motor or if a certain series of motor has issues. that could give you at least a little piece of mind.
Old Feb 17, 2021 | 10:31 AM
Srrmc's Avatar
Srrmc
the words i could should be I would
