OK.... my current battery is about 3 years old. I noticed over the weekend the volt meter showed' just below 12v with the ignition on. Starts ok, no hesitation. When running, volt meter reads about 12v. So I guess it's about time for a battery replacement. My question is this: Is the lithium battery worth the extra cost over the AGM? Any major down fall with the lithium? I feel confident with replacing with AGM, but am just curious on the lithium. Your thoughts.
And yes, I did a search but did not find anything.
Initially we had a fair amount of HD lithium battery failures. It's tapered off a bit since but so have our sales of those batteries. One of the claimed benefits of that style is a claimed weight savings of eight pounds. My opinion is that weight savings will only help when installing or removing it. Eight pounds of weight in an 850 lb. bike isn't going to make much of a difference. It also requires a specific tender. Longevity is unknown because they haven't been out for very long. At almost twice the cost, I'd stick with the AGM. Keep in mind this is assuming you're looking at HD batteries. If it's another brand, longevity and failure rate is something I'm not familiar with but negligible weight savings and cost (+ the new tender) still have to be considered.
I am leaning towards the AGM.... trying to figure out what batteries Eastern Penn make (they own Deka which makes HD batteries). Trying to see if there is something out there other than HD. And I forgot to check on my way home from work today, but usually runs 14v+ when running. I may have noticed the 12v at idle. So I'll be checking again. Maybe time to get the volt meter out and do some real checking. I have always viewed the factory gages and a semi-reliable unit.
If you are not having problems turning the engine over with your current size battery I see no need for the expense of a lithium battery. I put one in because the stock AGM battery did not have enough CCA's to turn my engine over in cooler weather.
Before going through all that, could you verify those 2 numbers using a good known digital ( or good analog) voltmeter/ multimeter vs. what your bikes voltmeter is telling you?
I get 7 years out of a lead-acid battery in my Shovel. Check your charging system.
Lithium doesn't like cold, needs a special tender and is expensive. I wouldn't trust one any farther than how long it would take me to yank it out of there in the event that it spontaneously combusts.
AGM still works best IMHO, skip the lithium batteries.
Are you sure you have a battery problem and not charging system issue?
A battery that gets too much voltage takes a while to go bad (as the electrolyte boils away) , one that is not getting enough voltage (usually about 2 more volts than the battery is rated for) will not fire the bike up after a few starts/trips as it won't have the stored capacity even if the voltage reads close to spec.
Charge it out of the bike using 2 amps as a charging rate so as not to overheat the plates, then load test or check the specific gravity using a old fashioned hygrometer.... they are fairly cheap
I was told by my Harley Tech that the gauges are worthless.
My is always pegged over 16V.
They checked my regulator and it's fine.
I would never trust the gauge.
Like was said before, check it with a good volt meter.
