View Poll Results: Red shift 468 and pushrods
Red shift 468
100.00%
468
0%
Rs 468
0%
Pushrods
0%
Lifters
0%
Voters: 2. You may not vote on this poll
Red shift 468, pushrods and lifters
Old Jun 14, 2021 | 01:49 PM
rajavarumen's Avatar
rajavarumen
Stage II
Default Red shift 468, pushrods and lifters
Getting ready to purchase a redshift 468 cam for my 2018 Street Glide and was wondering if i should just maintain with my stock pushrods and lifters ? Or go with the kit from fuelmoto ( adjustable pushrod and lifters )
Can I maintain my original pushrods and lifters or should change them too?? If I maintain the original pushrods and lifters, will it effect other parts ??
Old Jun 14, 2021 | 02:00 PM
Scarydog's Avatar
Scarydog
The job is easier with the quick pushrods. You won't have to open the rocker boxes. Since your in there may as well upgrade the lifters since harley ones are minimal. Most of us also replace the lifter guides with the aluminum ones. You should also be upgrading the cam bearing..... since your in there.
. Go with the kit. Best option, do it right the first time, ya know.
Old Jun 15, 2021 | 01:08 PM
Dynamick's Avatar
Dynamick
What's the difference between the first three poll choices?
Old Jun 16, 2021 | 09:41 AM
pgreer's Avatar
pgreer
You don't mention the mileage, but I almost always replace the lifters when installing a cam regardless of the mileage. There are much better options than the OEM lifters, ie S&S, Hylift or Fueling. And quick install style pushrods, while they are not cheap, they eliminate the need to remove the rocker covers which reduces labor to install the cam.
The survey didn't allow the option to chose more than one radio button, or I would have selected cam, lifters and pushrods.
Paul
Old Jun 29, 2021 | 02:45 PM
rajavarumen
Stage II
how about the chest cam and oil pump?
Old Jun 29, 2021 | 03:41 PM
pgreer's Avatar
pgreer
HD updated the oil pump in 2019 in response to sumping problems on some bikes, so I'd get the latest oil pump form HD unles yours already has it (I doubt it does). It's good insurance since you are in the cam cover anyway. They are surprisingly inexpensive for a genuine HD part. The cam plate should be fine for your application.
Paul
Old Jun 29, 2021 | 07:54 PM
Skyway's Avatar
Skyway
My 2019 Roadglide had a June 21 2019 build and it had the latest version oil pump. My mechanic still changed lifters and pushrods when he installed the Redshift 472 cam.
BBobJ
Engine Mechanical Topics
May 9, 2020 02:42 PM
rainsong
EVO
23
May 1, 2017 09:30 PM
shineybike
May 16, 2013 07:48 AM
omgtkk
EVO
Aug 28, 2010 02:57 AM
