Heel or Toe?
Old Jun 20, 2021 | 12:36 PM
gonemad's Avatar
gonemad
Heel shifter here. I wear size 13-14 so I installed a 1.5” extended heel shift lever from softbrake to free up the available real estate on the floorboards.
Old Jun 20, 2021 | 12:56 PM
Herbherb's Avatar
Herbherb
Heel shifter was crazy when I first got it. Stalled out a couple times lol. Once I got use to it I love it. Keeps my shoes fresh and clean.
Old Jun 20, 2021 | 01:06 PM
itsdug's Avatar
itsdug
Some of you guys have big feet.
Old Jun 20, 2021 | 01:43 PM
A1A's Avatar
A1A
I think if you have a heel shift lever one should learn to use it. But if you don't want to learn or use the heel shift lever just take it off and upshift and downshift with the toe.
Cheers
Old Jun 20, 2021 | 01:51 PM
hardheaded's Avatar
hardheaded
I always take the heel shifter off of my bikes, just don't care for it. The other thing about heel shifters is you tend to stomp on them and that will cause problems.
Old Jun 20, 2021 | 02:13 PM
Dehammer's Avatar
Dehammer
I tried the heel shift and seems like a lot of wasted movement. Lifting a leg to stomp through gears proved how lazy I am.
I've used toe shift since I was a kid so I'm used to it. Don't care about pretty footwear.
I did fall in love with floorboards though. I keep the allen wrench to adjust it in case someone with thick boots would need to use it.
Old Jun 20, 2021 | 04:24 PM
470004's Avatar
470004
I only use the heel shift to go from 1st to neutral.
Old Jun 20, 2021 | 04:27 PM
Jackie Paper's Avatar
Jackie Paper
Once you get the hang of heel and toe, you'll never go back.
Or at least want to. If you came from toe only, it at first seems *** backwards. In a few days, it's great.
Old Jun 20, 2021 | 04:35 PM
stro1965's Avatar
stro1965
I get confused when I ride a bike without a heel shifter! Lol
Old Jun 20, 2021 | 04:37 PM
StoneTrekker's Avatar
StoneTrekker
I grew up and learned on bikes that were toe shifters-only. Getting my first H-D and using the heel shifter was awkward at first but I've grown to prefer it. I'm a lazy rider and I also want ALL my footboard available. I installed toe and heel extended shift levers from Softbrake. The heel shifter is adjusted so I simply drift my boot heel over the back edge of the board and rock my foot. The heel peg is basically on the same level as the board. My toe unit is extended (and lowered) forward to give maximum board space. It takes almost no effort to get on it and downshift quickly. I'm so vain....I prefer no scars on my boot tops. Plus...and more truthfully...there's just something very Harley-esque about heel-toe shifting for me.
