I hated heel shifters the first few times I rode bikes with them. Was constantly hitting the shifter as I put my feet up on the floor boards taking off from a stop, which resulted in my hitting 2nd gear way to soon and almost stalling the bike.
When I got my ultra classic back in August my plan was to remove the heel shifter. But after a couple tanks of gas I was used to it. I only have a size 10 1/2 boot, but I would still like a little more room, I'm thinking about adding an extended heel shifter.
I ride my daughters Sportster occasionally and have no problem switching back and forth.
28 years ago I bought a bike with a heel shifter. I figured Id try it then take it off when I got the bike home. By the time I got home from the dealer I understood why the heel shifter existed. 28 years and 250,000 miles later I wouldnt be without it.
For me, trying to upshift with a toe shifter and footboards is too awkward as I have to pivot my foot at the rear of the heel instead of the instep, as I would with foot pegs. This requires different and less efficient muscle groups to upshift.
Stomping on the heel shift ,( sigh.) Gotta be an animal to do that. If you can toe shift it , what makes you think using your heel would take any more effort ?
Both my Harley's have had heel/toe shifers and have grown accustomed to them. Thing is, I don't usually hit the rubber at the end of the heel shifter. I end up hitting the heel shaft instead and rarely ever miss a shift.
I started riding with toe shifter only, always took the heel shifter off. Tried it a few times and got used to heel shifting and have never looked back. I keep the heel shifter on the new bikes now and use it religiously. Now for the question no one has asked yet. . . how often have you heel shifters had a brain fart and downshifted when you meant to upshift?
I find that I have more dexterity doing upshifts with my toe. Stomping down as mentioned is more likely with me, because in order for me to upshift with the heel, my foot needs to hang in the breeze unsupported. Finding neutral for me is made easier by downshifting with my toe to first and then tap it with my heel to the neutral position.
