I prefer frame and handlebars/tripe tree. I prefer ratchet straps (not junk ones) to cam straps - even though I say that Laidlaw uses cam straps. Safety clasps on the hooks make sense because if bouncing enough a strap could momentarily lose its tension and the hook could become unhooked. My current set up doesn't have the safety clasps however and have never had a problem but I use four straps on the front (2 frame and 2 handlebar/triple tree) and two in the back - typically off of the passenger pegs. Condor (or equivalent) makes life easier, especially if doing this by yourself.
I got this brand new Maxxtow wheel chock off of facebook marketplace for $70, and I bought these harley straps, I'm sure there are less expensive solutions, but I didn't have the time to shop around, I wanted my bike tow to be solid and problem free and it was. I strapped the handlebars on both sides, I'm not even sure I really had to with this wheel chock, it really works well.
FWIW, I once transported my BMW R100 from South Dakota to Michigan in the back of a 16' U HAUL box truck with nothing to secure the bike other than the coil of rope that I bought at the U HAUL store. Everything went fine, it's not rocket science.
I always use rachet tie downs behind the lower leg above where the fender bolts to it. The only compression is minimal on the tire to the chock. I always use a chock. Tie downs compressing the suspension or worse the bars risk blowing a fork seal why do it. Thats like jambing on your front breaks unnecessarily. If you have a security system remember to put it in travel mode.
If the bike is newer with a security system, don't forget to put it in trailer mode or disconnect the battery,
Or you could just keep the fob with the bike.
BTW, I have HD tie down brackets attached to the front of my Ultra. They attach to the running light bracket bolts, so they are high on the fork.
I've never had a problem partially compressing the front end.
