Looking for gear recommendations
Old Sep 17, 2021 | 12:06 AM
  #31
Mississippi Drifter's Avatar
Mississippi Drifter
6th Gear
Default Myself.
I always wear jeans and my work boots, which are 16 inch tall lineman boots. I usually wear my leather vest, mainly because I need pockets, but sometimes I only wear my t shirt. I have a fox creek leather jacket and with the vents open I stay comfortable on the highway but give me 5 minutes in traffic and I'm thinking about running lights.
Old Oct 2, 2021 | 09:52 AM
  #32
MotoDude's Avatar
MotoDude
Originally Posted by Christos0720
Hi everyone!
I just got a 2021 Softail Slim in gloss black.
I want to be safe, but I also don’t want to look stupid. I see a lot of people riding around in t-shirts with sneakers. That’s definitely not good enough, in my opinion.
What are your recommendations for helmets, eyewear, jackets/upper body, gloves, pants/lower body, and footwear?
Hey Christos,
I am very late to this conversation, but hopefully this will be useful info. I have done way too much research on riding gear. Highly technical stuff available now.
Helmets - this is a lot of research available online regarding brain injuries. The EU is pretty advanced with this research which influences the ECE standard. Rotational force on the brain is key. The short of it - I strongly recommend not getting a Snell rated helmet - get an ECE. Snell tends to be much heavier which can cause more rotational force. Carbon fiber helmets are extremely light and strong. Some polycarbonate helmets are light and well made. They are also less expensive. Be sure to accurately determine your head shape - oval, intermediate oval, etc. Revzilla explains how to do that. Helmets are designed for different head shapes. Get an accurate measurement too. Consider that some helmets will use the same shell size but use different thickness pads for sizing. Example - the Large and XL helmet could be the same shell, but the pads are different sized. This might be helpful if you are between sizes. When I was carrying some extra weight (fat face), I used the Large size crown liner and replaced the check pads with XL. Venting is key of course.
There are a lot of high-tech fabrics available. Check eurofibers.com - they have info about these fibers. Understand that there are different branding names for the same fibers - HMPE fiber is branded as Dyneema and others. I have a pair of Klim jeans that are lined with Kevlar. They are a bit heavy and hot, so I wear these on the cooler days. I have a pair of the Harley FXRG Armalith jeans - excellent. Also have a Pando Moto skins that I wear under my Levis, etc. I have the same skins for my shirt that I wear under a long sleeved shirt. Lots of shirts, jackets, etc available with these abrasion resistant materials.
Have fun with the research.
Cheers,
MD
Old Oct 4, 2021 | 10:39 AM
  #33
Deal Breaker's Avatar
Deal Breaker
Hi everyone! I just got a 2021 Softail Slim in gloss black. I want to be safe, but I also don’t want to look stupid. I see a lot of people riding around in t-shirts with sneakers. That’s definitely not good enough, in my opinion. What are your recommendations for helmets, eyewear, jackets/upper body, gloves, pants/lower body, and footwear?
Lots of good, informative posts above regarding riding gear. In my view, wearing a full compliment of riding gear can be summed up as, "Better to have it and not need it, than to need it and not have it." Being in a no-helmet law state, I see riders all the time without helmets and other protective gear, and while I'm in favor of their freedom to make these choices, my choice is to wear protective gear. Good luck with whatever you decide!
Old Oct 4, 2021 | 10:47 AM
  #34
Christos0720's Avatar
Christos0720
Originally Posted by MotoDude
Hey Christos,
Cheers,
MD
You’re not late to the conversation. I’m always looking for advice and ideas.
Thank you for the recommendations! I have some reading and research to do.
Old Oct 4, 2021 | 12:34 PM
  #35
Ingramite's Avatar
Ingramite
Default I'm Noticing
That no one has mentioned a motorcycle cape.
On a clear day it flies out behind you like the most effective Caution Flag. Our eyes are naturally drawn to movement. Your Motorcycle Cape will draw the attention of every car on the road.
When it rains you turn the cape around to shelter your body from the elements. Also useful at the Chinese Buffet.
I was able to acquire a pair of matching gauntlet gloves and knee high boots. My matching Kovid mask is on back order though.
Above all else, avoid camo gear. Ya know, for obvious reasons. The last thing you want is for someone to mistake you for a duck hunter
alantry
2014-2024 Touring Models
25
Jan 2, 2020 10:44 PM
ArgusDave
Oct 20, 2012 01:23 PM
casteel
May 2, 2012 01:06 PM
Dallas852
May 2, 2012 10:36 AM
MNPGRider
May 2, 2010 08:41 PM
