What do you call the black plastic sleeve around wire harnesses?
Old Aug 19, 2021 | 12:29 PM
Mchad's Avatar
Mchad
Default What do you call the black plastic sleeve around wire harnesses?
I’m doing some rewiring and I want to replace the flexible black sleeves around wire bundles, but I can’t find anything on Amazon - all that shows up is either the woven nylon loom or the corrugated split plastic stuff. I can’t find the smooth, shiny (pvc maybe?) stuff Harley uses for pretty much any harness on the bike… Any ideas what to search for? Thanks.
Old Aug 19, 2021 | 12:31 PM
OKMICK's Avatar
OKMICK
Look at these sheathing options
http://www.cycleterminal.com/sleeve-tubing.html
Old Aug 19, 2021 | 12:39 PM
piasspj's Avatar
piasspj
Here ia an option that popped up on a quick google search.
https://www.ebay.com/itm/262963995540
Old Aug 19, 2021 | 12:41 PM
Mchad's Avatar
Mchad
That’s the answer. Thank you very much. Ordering now.
Old Aug 19, 2021 | 12:42 PM
Mchad's Avatar
Mchad
Yeah I hadn’t tried “PVC” - that’s the operative word. Thanks
Old Aug 19, 2021 | 12:43 PM
Juan L's Avatar
Juan L
Moderator
When you use this stuff, after cutting to length, make sure you use a flame to seal the ends or it will come apart and look like ***.
Old Aug 19, 2021 | 12:44 PM
JustDave13's Avatar
JustDave13
The trade term is wiring loom. In case you want a better search.
Old Aug 19, 2021 | 12:47 PM
Mchad's Avatar
Mchad
Well, that’s definitely the case for the mesh loom I already have plenty of. The stuff I was looking for is solid flexible tubing that cuts smoothly. No need to melt the ends.
Yep, I was using that term, but all I was seeing was the split or woven nylon stuff. Adding PVC got the exact results I was looking for.
Old Aug 19, 2021 | 12:49 PM
RHPAW's Avatar
RHPAW
I call mine Tyrell. It's an African name meaning "stubborn", which fits right in with electrical wiring.
Old Aug 19, 2021 | 12:50 PM
Juan L's Avatar
Juan L
Moderator
Numerous automotive applications are available, many aircraft grade as well.
Use the search terms, "wiring loom anti-chafe"
