Bad ECM Tester
Old Aug 28, 2021 | 05:52 PM
OGBlackout's Avatar
OGBlackout
Default Bad ECM Tester
Hey guys,
I’m a tech at Harley and I’ve come across a ton of problems so far bad one that baffles me still is the ECM being bad. You end up following the tests in the electrical book and it seems like half the time the book just guesses that you need a new ECM even if you have a gut feeling it’s not. Luckily for me it’s been right most of the time just because I triple check every connection before telling a customer they need a new ECM, but it’s just really surprising they don’t have a tester you can plug in the ECM, hook up 12.6 volt connection and have it cycle through each connection to see if it actually is bad. There is nothing like it on the market and wondering if that’s an idea that would be worth it to try and figure out. Or if someone here knows a little more to the reason why there’s no way to test them. If it’s just not worth it or maybe some of you that are more experienced have a good test you came up with. Basically just kinda opening up conversation about it, would love to hear some input.
Old Aug 28, 2021 | 06:20 PM
GalvTexGuy's Avatar
GalvTexGuy
Isn’t that one of the functions of the DTII along with troubleshooting DTCs?
ajtwin's Avatar
ajtwin
Originally Posted by OGBlackout
Hey guys,
If you're a Harley tech, you have an "ECM tester" right there.
Get a SST ECM for your department. Regular ECM, known good, just for testing.
Plug the special service tool ECM into suspect bike.
Same issue? No issue?
Old Aug 28, 2021 | 06:57 PM
OGBlackout's Avatar
OGBlackout
To a point, it will give you idea where to test, like today I had a customer come in with a code throwing “rear coil high/open” the wire from the coil goes directly to the ECM so all I could do was test the continuity of the wire from coil to ECM, which was good, but didn’t give me 12v to coil when ignition was pressed. I used a coil from a different bike to test coil just as a second test but it did the same thing. Which means the ECM was bad. Put a new one in and his bike ran great no codes and fixed the open. So it’s bitter sweet with DT cause it could be bad ECM or a short in the wire somewhere, luckily coil wires are short so it’s easy to trace. But on other problems it’s a pain to trace
Old Aug 28, 2021 | 07:02 PM
OGBlackout's Avatar
OGBlackout
Good thinking, but the only problem with that is ECM’s marry the VIN to the ECM. So once it is “tested” on another bike, that’s it, can’t use it anymore other than that bike. That’s why it’s scary to diag cause if the ECM isn’t bad, the customer spent 3-400 dollars for no reason. That’s why I’m surprised they haven’t made a diag tool specifically for ecms lmao. But it’s also the same for hydraulic lifters, they collapse on themselves but there is no way to test them, you just have to be sure by sound they are bad
Old Aug 28, 2021 | 07:50 PM
GalvTexGuy's Avatar
GalvTexGuy
Surely that’s not something you tell your customers! If it is, I’m glad I work on my own bikes. At least if I’m changing parts hoping I changed the right part, that’s on me. I’d have a fit if a technician told me I bought an expensive part I didn’t need because he couldn’t diagnose the problem.
Old Aug 28, 2021 | 08:06 PM
hardheaded's Avatar
hardheaded
If HD is selling and making a profit on ECM's there is no way they will be of any help diagnosing the problem. The auto industry has the same problem. Once you marry the new ecm to the car or truck, it's over.
Old Aug 28, 2021 | 09:30 PM
Ed Ramberger's Avatar
Ed Ramberger
Pretty sure if you followed the diagnostic trees properly this wouldn't be an issue. Book doesn't "guess" that you need an ECM if the tests are performed correctly.
Old Aug 29, 2021 | 02:45 AM
General Hangover's Avatar
General Hangover
I made another experience with my 92 Eglide and the official electric manual. They describe o lot of procedures to check the self canceling turning module. I did them all and the diagnosis was that I've to replace the module. I wouldn't believe that and did some voltage drop measurements. And voilŕ: It was just a short circuit in one case of the turn signal lamps.
Nearly 30 years old stuff - but I bet it's the same thing still today.
Old Aug 29, 2021 | 06:39 AM
OGBlackout's Avatar
OGBlackout
Nooo you misunderstood a little, I do make sure 100% that it is the problem, I just go about it my own way and do tests that I think work better than some in the manual. I would never want to make a customer pay for something they don’t need.
