Tips
Old Aug 8, 2007 | 09:05 AM
swestbrook60's Avatar
swestbrook60
Default Tips
What tips can you more experienced riders give on how you determine the road may be slippery or present a potential hazard before you enter the dangerous area? We know about painted surfaces, manhole covers, etc. but are they ways you have learned to spot unexpected moisture, diesel fuel, sand, asphalt sealers, or anything else that can be slippery? What do you look for when approaching a corner or a curve?
Old Aug 8, 2007 | 09:30 AM
1200babe's Avatar
1200babe
Default RE: Tips
just always assume that what you can't see will hurt you- slow down in the curve until you see it is alright- then accelerate going out of it.
Old Aug 8, 2007 | 09:42 AM
dadofsix's Avatar
dadofsix
Default RE: Tips
During the summer, watch out for grass cuttings in a hard curve after a light rain. In the fall, watch out for wet leaves in a curve. Both of these can be slicker than pig-snot if you're not careful.
<><Peace
Old Aug 8, 2007 | 09:44 AM
Fandango6's Avatar
Fandango6
Default RE: Tips
You probably already know this, but any time it's been real hot for a long while, be careful after a rain as it will bring oil to the surface. Also be leery after a thunder storm or heavy rain as it will wash gravel out into the road, seems to always be in the turns.
Old Aug 8, 2007 | 09:52 AM
whaap's Avatar
whaap
Default RE: Tips
The tar strips (tar snakes) that are used to fill long cracks in the road can be treacherous if hot from the sun or wet from rain. Because the road is o.k. where you're at, don't assume (*** of u and me) that it will be o.k. in and around the curve that you can't see.
Old Aug 8, 2007 | 09:57 AM
JamieCarr's Avatar
JamieCarr
Default RE: Tips
ORIGINAL: dadofsix
<><Peace
Thats a big one I look for too,.......overhanging trees make me slow down and look. Especially if they've been on the road for awhile.
zombie's Avatar
zombie
Default RE: Tips
As impractical as it may be...ride dirt. I don't think any single thing can prepare you for the street like dirt bike riding, searching for things that will take you down, like sand on hardpack andwallows,becomes second nature. It's also easier to learn, on a 200lb bike,how bikeshandle in certain situations and what you have to do to correct for it than a 700lb scoot.
Barring that, constantly scan and keep your eyes moving, don't become focused on any single point. Search the road for anything that looks abnormal...different coloring of the road surface (darker asphalt, debris etc.) and err on the side of caution...that area that only looks like a patched piece of asphalt may be oil.
I usually keep a little manueverability on hand (don't push it to the edge) when cornering so that if I have to make corrections in a curve I can. I try not to brake in a corner (occasionally a decreasing radius turn forces me to bleed off some speed, but I try to avoid it at all cost). Cornering reduces the amount of contact patch that is available for keeping the scoot upright and even less for braking, if at all possible bring the bike upright to brake in a corner.
Set up for a corner, brake before entering and accelerate through the curve. This sets the suspension and the bike and prevents the scoot from getting squirrely in the corner and also allows for any adjustements you need to make while cornering.
Take my advice for what it's worth...it's free and you usually get what you pay for
Old Aug 8, 2007 | 10:31 AM
Hdbiker1450's Avatar
Hdbiker1450
Default RE: Tips
ORIGINAL: whaap
I second it, whaap. Those buggers scare the crap outta me![:@]
Old Aug 8, 2007 | 10:38 AM
wisemx's Avatar
wisemx
Default RE: Tips
One thing that is often over looked...
Watch areas where vehicles may have over heated.
Those areas may have anti-freeze on the road and it's nearly invisible.
Such areas are typically the end of exit ramps from Highways, intersections, etc.
Old Aug 8, 2007 | 10:48 AM
bigtop1's Avatar
bigtop1
Default RE: Tips
I second Zombie's input. Riding dirt teaches you a lot. Prepares you for those blasts of reality.
