leak down test
Old Oct 23, 2021 | 02:49 PM
adm's Avatar
adm
You can buy a compression tester for about $20 on Amazon. It's well worth having one for cars, bikes, boats etc...just for peace of mind.
It only takes a few minutes to do a test.
Old Oct 23, 2021 | 03:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A lot of people don`t understand what a leak down test is, and what the numbers mean.
Most leak testers are el cheapo junk, and will have readings that won`t be the same as another tester of the same type.
The leakdown rate doesn`t tell you a lot, since it is just the difference between the air supply pressure and pressure after the orifice, which is not standardized or calibrated (except on units approved by FAA).
A leakdown test is a great tool, but you must have a baseline to compare it with.
Buy a leakdown tester, test the leakdown yourself when the engine is just broken in.
Now when you take a subsequent leakdown test (using the same tester) you will know how much difference there is.
In my opinion, a leakdown test performed at dealer using some junk Chinese tester is just generating numbers that don`t mean anything.
Do a compression test.
Old Oct 24, 2021 | 03:25 AM
General Hangover's Avatar
General Hangover
[...] Do a compression test.
Compression test and leak down are different things in my opinion. While a compression test just tells you the value of the compression generated by starter and battery, the leak down tells you the ratio between he sends in and what's come out. So it's more exact and allows conclusions to be drawn about the condition of the engine - even with the Chinese crap I never would use.
To judge an engine I prefer the following way:
  1. Do a compression test. If it's not noticeable enjoy the ride. If yes, go ahead.
  2. Do a leak down to know why the compression is low. The leak down helps you indicate the source of the failure:
    1. Intake: While carburator or bridge removed, you can hear the air escaping.
    2. Exhaust: While exhaust removed, you can hear the air escaping here.
    3. Piston rings: Hear the escaping air makes sound in our oil tank.
    4. Head gasket: Use a brush and some soap. If you see bubbles, the head gasket is blown.
    5. Crack anywhere (cylinder head, combustion chamber): Same as #4.
If you want to do the leak down in a 100% way, you've to open the primary and block the sprockets with a steel. Doing a leak down by blocking the engine just with the clutch can be fail because if the clutch slips just a little way, the intake/exhaust beginns to open and you get a false positive.
Old Oct 28, 2021 | 09:28 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The crank would have to move more than just a little bit to cause a valve to open.
There is no reason to pull the outer primary cover and waste a quart of primary lube and possibly a gasket just to perform a leak down test, the clutch should not going to slip by putting 100 psi into one cylinder, transmission in high gear holding brake....
If it does, you probably do need to pull the outer primary cover....To replace the clutch.
You don`t really need 100 psi either, 80 psi will be just as accurate.
People use 100 because they don`t remember how to compute percentage of 80...
Old Oct 28, 2021 | 12:00 PM
RHPAW's Avatar
RHPAW
Just keep an eye out for skidmarks. If there aren't any, there's no leakage.
If there is, change your diet.
djs
Milwaukee Eight (M8)
32
Nov 27, 2021 05:30 PM
Johnnypop
Engine Mechanical Topics
Dec 10, 2019 10:26 PM
Ironyman
Ironhead
Oct 18, 2014 02:55 PM
2002bigbored
Jul 27, 2008 06:47 AM
98fxd
Exhaust System Topics
Aug 4, 2005 07:04 PM
