You will know if a spoke is loose if you tap it with the wrench a it sounds like a dull thud. When working around the wheel, tap each spoke, and if you have the spokes torqued properly, you will hear a consistent ring tone from each spoke when you tap it with the wrench.
If you need one in an emergency on the side of the Road, you Can use an Adjustable Crescent Wrench.
I had my rear spokes come loose after a high speed Wobble in the Twisties.
Then used to use a Screw driver to tap on each Spoke to find the loose spokes and tighten the loose ones up to a tight tone Sound With an Adjustable Crescent Wrench
to get home.
Tapping the spokes with a small wrench is part of routine maintenance on any bike with spoked wheels. I use a box end wrench to tighten them. It's also a good idea to check for wheel true/rim run out.
I feel stupid, what I thought were loose spoke nipples, are actually just my wheel weights from balancing, that was what i saw. Still a good idea to check my spokes though lol
I read somewhere that you tighten the nipple opposite of righty tighty?
Also if anyone can link me a wrench I would appreciate it. I'm seeing all kinds of stuff labeled spoke wrench.
No. think of the spoke as a long, thin bolt, and the nipple as a nut. The spokes are standard right hand thread, so you turn the nipple clockwise to tighten, like any nut.
For Harley-Davidson spokes, youll need an 8 gauge spoke wrench. I bought mine about 40 years ago so I dont remember where it came from.
