Air Pressure?
Old Aug 10, 2007 | 06:08 AM
coldbeerpirate's Avatar
coldbeerpirate
Default Air Pressure?
A ? for touring bikes. When loaded with gear and passenger,, what is your PSI on rear shocks.
I'm running about 25lbs and it still feels kinda mushy.
Old Aug 10, 2007 | 06:37 AM
jakedog's Avatar
jakedog
Default RE: Air Pressure?
I keep mine around 20#
Old Aug 10, 2007 | 06:42 AM
ckgdrums's Avatar
ckgdrums
I usually run about 18-20 when riding 2 up, and 14 solo. But, I think it's different between models or model years. I think.
Old Aug 10, 2007 | 06:51 AM
fatboylust's Avatar
fatboylust
All FLHs except FLHRS & FLHX
up to-150 lb solo rider 0 psi
150-200 lb solo rider 0-10 psi
200-250 lb solo rider 5-15 psi
up to 150 lb rider with passenger 10-15 psi
up to 200 lb rider with passenger 20-25 psi
MAX GVWR 25-35 PSI
FLHRS & FLHX (factory lowered rear suspension)
up to 160 lb solo rider 0 psi
160-200 lb solo rider 0-10 psi
over 200 lb solo rider 5-10 psi
up to 150 lb rider with passenger 20-30 psi
over 150 rider with passenger 25-35 psi
MAX GVWR 40-50 psi
With the addition of luggage and a passenger you can easily get to the GVWR.
FBL
Old Aug 10, 2007 | 07:36 AM
coldbeerpirate
I'm 220 lbs, and huney is around 125. My bike is a FLHX. i'll try adding up to 35 and give it a try. Thnx
Old Aug 10, 2007 | 09:03 AM
Fandango6's Avatar
Fandango6
Two up and loaded for trip I run 35 lbs, drop back to 22 at home. Had it to 35 for a trip recently andforgot tolower the pressure afterward and rode solo, like riding a hard tail, my achin back.[:@]
Old Aug 10, 2007 | 09:59 AM
Silverearl's Avatar
Silverearl
I keep mine at 35 and it seems to work great both single and double.. IMHO...
Old Aug 10, 2007 | 11:46 AM
wildwill's Avatar
wildwill
I keep mine at 15 most of the time. Usually ride 2 up on the RK.
ny2az
Touring Parts
14
Jan 31, 2016 10:03 PM
elky72ss454
Screamin Eagle CVO Models
Jul 13, 2013 02:20 PM
danosrs
Jun 17, 2011 03:17 PM
bonzo2
Mar 26, 2007 08:17 PM
Bubba Zanetti
Nov 13, 2006 01:00 AM
