Trickle Charge Set-Up
Old Apr 12, 2022 | 09:29 AM
470004's Avatar
470004
All my rides have the pigtail connected to its battery using a battery tender charging system.
Old Apr 12, 2022 | 10:03 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Same as above.
Old Apr 12, 2022 | 10:17 AM
jwt873's Avatar
jwt873
My dealer supplied a brand new genuine Harley Davidson 750 mA battery tender. (Most likely made in China).
I was surprised to find it in the saddlebag along with the owners guide and other documentation after they delivered the bike. It plugs in the bikes pigtail. I leave the pigtail hanging just visible under the side panel so it's always easy to access.
Normally in the summer I don't use the tender. I never let the bike sit for more than a couple of days without riding it.
Old Apr 12, 2022 | 11:13 PM
crtfibl's Avatar
crtfibl
Pigtail with fuse, used a cable tie to keep it in place under the seat but just hanging out enough to attach the charger, and also have a "cigarette lighter socket" in the same side bag that I can plug into the battery pigtail for phone charging (though never used it!).
Old Apr 13, 2022 | 05:00 AM
Bone Doc's Avatar
Bone Doc
Originally Posted by MURPHCC1
I use a battery tender, not a trickle charger and yes, the pigtail connected to the battery with a inline fuse.
^^^ This
Chief, you're showing your age. Trickle chargers went out with rotary phones.
Originally Posted by Calif Fat Bob
3 bikes in the garage all with Deltran Battery Tender Juniors on them. All 3 have pig tails. (KTM 790, KTM 1190, Harley Fat Bob)
The Deltran Battery Tender Junior is probably the most popular tender. I have one on all vehicles with a battery (cars, motorcycle, tractors, mowers).
Old Apr 13, 2022 | 10:34 AM
SeniorChief56's Avatar
SeniorChief56
Going to hook up pigtail today....lithium batteries do not need to be on a tender like AGM batteries....I'll hook up tender as needed, depending on how much I ride
Old Apr 13, 2022 | 11:52 AM
White Ice's Avatar
White Ice
Battery Tender mounted on top of the garage door motor with the cable hanging down. Ride in and plug it in before getting off the bike.
Old Apr 13, 2022 | 03:20 PM
adm's Avatar
adm
Yep. Pigtails on all my bikes. These days, most are factory installed and part of the main wiring loom. I use Optimate and Noco tenders/chargers.
And I put a Noco battery harness on each bike so that should I need to, I can easily jump start the bike. The new Softails and Pan Americas are a pain in the *** to access the battery to use alligator clips and you can't get to the starter motor either. It's either use a big screwdriver or a harness. After you have done the screwdriver trick a few times, you know adding the harness makes sense.
gros21
Audio Systems
Jul 16, 2021 11:45 PM
ElectraJim
Jul 12, 2018 02:43 PM
rquest
Aug 1, 2017 05:24 AM
Clash City Rocker
Mar 4, 2014 08:02 PM
Blacklion213
Nov 7, 2007 09:53 PM
