Thoughts on this type of oil change.
Old Jun 22, 2022 | 03:58 PM
scotttemp59's Avatar
scotttemp59
6th Gear
Default Thoughts on this type of oil change.
About to switch to full synthetic oil after 2000 miles on full rebuild of 03 B twin cam. Balancers removed by dark horse, crank rebuilt, b and B, up at 97” now. New s&s camchest and on and on and on. I found this guy getting all the oil out. I run thundermax ECM now also. Wonder about turning over with the plug wires off? Can that cause problems. Should I really consider this or should I just not be such a baby and ride, drain, fill like a normal human. I don’t mind the extra work. I do think this would be better done with warm oil after 15 mins of riding. Let me know if I’m stupid for even thinking I should do it. As for the synthetic oil I am using, I won’t say as everyone hates not the one they use. (Redline 20-60) 😀. It’s hot AF here in Utah during summer.
https://youtu.be/K0dd76MBwDg
if link does not work search “full purge oil change softail” on youtube delboys garage video.
open to your answers but try not to be to mean😀
Old Jun 22, 2022 | 04:14 PM
Jehu's Avatar
Jehu
... just not be such a baby and ride, drain, fill like a normal human ...
You said it; I didn't - but to this I agree.
In all my years and hundreds of thousands of miles of motorcycle riding I have never (NEVER!) seen or heard of an engine that failed or prematurely suffered undue wear from using the wrong oil ... ever! Ditto for cars, trucks and engines powering heavy equipment.
(*) There have been problems with aircraft engines and certain oils - but that's a different application and situation.
Old Jun 22, 2022 | 04:18 PM
scotttemp59
6th Gear
kinda what I thought. Just being a baby as it cost a little bit to redo this motor. Just a little bit😀
Old Jun 22, 2022 | 04:32 PM
Spartanden's Avatar
Spartanden
That's what I would do.... ride it a couple miles and thoroughly warm the engine up. Bring it home, and let it sit for a few minutes while you get your things around. Drain and change filter. I usually wait until the drips from the engine are really slow. Fill and check. I would ride as you should have been instructed for break in, if anything. But I would not worry about synthetic oils.... I use Amsoil. You should have no problems!!
Old Jun 22, 2022 | 05:36 PM
Gas Smasher's Avatar
Gas Smasher
Is the concern about mixing synthetic with some residual dino oil? If it is, I would say it isn't anything to worry about. If you are concerned, call Redline and ask them about the compatibility of the oil you are using with what you are switching to.
People have their own ideas about doing things, and mostly I don't care, but there are some things in that video I think are just silly.
Old Jun 22, 2022 | 05:37 PM
AJSHOVEL's Avatar
AJSHOVEL
On a normal oil change I wouldn't worry about it. I change my oil frequently anyhow.
You, however, are breaking in a rebuilt motor. Why do we change oil soon after running a fresh rebuilt motor? To get all the filings (that absolutely will be there) out.
A complete purge of all your oil is what you want.....after all, you just spent a ton of cash on a rebuild, you don't want any of the break in filings in your oil...do you?
As for turning over you motor with spark plug wire disconnected.....won't hurt a thing (how could it?).
Nothing wrong with a good synthetic oil.....just keep it fresh and clean.
Old Jun 22, 2022 | 05:51 PM
TriGeezer's Avatar
TriGeezer
I’ve seen earlier cars f up rod bearing from running too light of an oil. And cylinder walls scored from crap oil. But, the biggest issue is running low or not changing the oil.
But, about 15 years ago I bought an older Honda 250 to practice for and take my Oregon test. It was about 8 years old, and was never garaged. But, I got it cheap. I don’t think the guy ever changed the oil. It was thick black and came out like tar. 3 change outs and running it to warm up, and it came pretty clean. And after that it ran like a top, and didn’t smoke at all…except 3rd was stripped. But, who really needs all the gears. Well, it was a Honda…I wouldn’t ride a Harley 75,000 miles without changing out the oil.
Old Jun 22, 2022 | 06:36 PM
ahhlou's Avatar
ahhlou
Take a 15 minute ride, then change the oil and filter as per the owners manual. If the MoCo though it was necessary to do a full purge, it would be documented in the service manual.
Never had a bike engine fail following the maintenance schedule... yet...
Old Jun 22, 2022 | 07:07 PM
Stowe's Avatar
Stowe
If you're concerned about residual oil after your oil change, just run it 500 miles and change it again. I dont think it's necessary, but if it makes you feel better, then it's money well spent. That should get all the old stuff pretty well flushed out. Personally, I'd just change the oil and call it good.
Old Jun 22, 2022 | 07:10 PM
smitty901's Avatar
smitty901
Way over thinking this. Change your oil run what you want and enjoy.
