Road King Help
Old Sep 21, 2022 | 11:15 AM
Vipers Harley's Avatar
Vipers Harley
Got the video to go.
Sounds like starter to me staying engaged. When you shut off the bike you hear what sounds to me like starter spinning down, 🤔
The answers are in this thread
Old Sep 21, 2022 | 12:14 PM
Rounders's Avatar
Rounders
I wouldn't be surprised your jack shaft shows wear. Maybe gear on clutch too. Not sure if you need to pull clutch to see it. Left hand thread on clutch if you do. Right hand on front comp nut.
Primary plug often has metal on it. Don't freek right away.
One thoery is start is engaged and hitting backside of gear while running.
Probably not good for starter. I'd consider replacing if you see damage. at least starter clutch. But maybe whole thing is probably best
Plus once you have starter off on that year, might as well replace, if damaged.
Old Sep 21, 2022 | 01:20 PM
bulldog1776's Avatar
bulldog1776
Thanks guys.
Old Sep 22, 2022 | 01:24 PM
Rob Harper's Avatar
Rob Harper
I can't directly help with the issue, but I have a 2001 service manual in case you need me to look something up for you.
Old Sep 29, 2022 | 08:43 PM
bulldog1776
UPDATE:
Thanks guys for the help. It appears the start switch buttons on the handlebars had went bad causing the starter to engage at times. I haven't had anymore weird noises since having that replaced.
Old Sep 29, 2022 | 09:08 PM
MyFavRk's Avatar
MyFavRk
Glad to hear you got to the root of the problem , was an easy fix , hopefully not to expensive .
Thanks for posting your update , this thread will definitely help others in the future with the same issue , appreciate it .
Ride safe !!
Old Sep 29, 2022 | 09:13 PM
Vipers Harley
Originally Posted by bulldog1776
UPDATE:
Your welcome!
Old Sep 30, 2022 | 10:44 AM
Rounders's Avatar
Rounders
Did you open primary to look for damage? I'd also be concerned you burned up starter
Old Oct 2, 2022 | 08:55 PM
bulldog1776
A shop did the work on it, but I don't think he looked at the primary. If the starter was hanging up and engaging which I believe is what was causing the noise. Would that possibly damage something in the primary? I could go ahead and change the fluid, if i need to.
The starter is working fine now, so I don't know?
Thanks.
Old Oct 2, 2022 | 09:11 PM
Rounders's Avatar
Rounders
Since you are supposed to limit cranking on a starter to seconds, and yours went for miles, I dunno.
My guess, with zero way of knowing,is Jack shaft sat and spun against starting gear on clutch. Maybe just scored it. Obviously wasn't engaged.
No load maybe. Maybe just spinning. I have to think shortened life of starter or starter clutch.
Changing a starter on 5speed. is more labor. I would have opened up to inspect. Probably replaced starter clutch or more.
All depends on how much you want to spend and how much you ridem
Hopefully you listen to kick back and grinding, if it does. Hopefully gives warning before it dies wrong spot.
My guess is starter might die prematurely. Dunno
Slamfire
Electrical/Lighting/Alarm
Aug 21, 2022 09:16 AM
rk10
Aug 3, 2013 07:51 AM
preksy
May 20, 2013 02:15 PM
Jesseluke22
Aug 24, 2012 06:36 AM
Rico450r
Jun 10, 2007 08:54 PM
