Handle Bars and riding position
Old Jan 27, 2025 | 06:53 AM
mseawell1022's Avatar
mseawell1022
Default Handle Bars and riding position
I’m having new bars installed on my 2013 Electra Glide.
What is the “starting point” to determine the most comfortable riding position? Should the bars be set so that I’m sitting pretty much straight up or leaning forward slightly? Any bend in the elbows?
I like to be sitting pretty much straight up. After long rides with the stock bars I tend to get sore/tight in my upper back/low neck area between my shoulder blades. I always felt like the bars should be brought back closer to me.
Thanks in advance,
Mark
Old Jan 27, 2025 | 07:05 AM
Notgrownup's Avatar
Notgrownup
For me I like my hands close to the height of my shoulders or a bit lower. A slight bend in my elbows ,,, Do you use a backrest? I like to sit on the bike and put my hands where I feel would be the most natural position then look a bar that would closely fit that. For me the 2x2 klockwerks works for me on my trike. Previously on my 07 Electra Glide i had Paul Yaffee 14”classic apes and I could go all day. I asked some guys at dealership events or on weekends if they liked theirs and most would let me sit on their bike to try the fit.
Old Jan 27, 2025 | 07:07 AM
TexasScooterTrash's Avatar
TexasScooterTrash
It's not rocket science. Sit on bike, slide the bars so ya sit comfortable, tighten riser bolts.
Old Jan 27, 2025 | 07:10 AM
mseawell1022
Yes, I use a backrest. My lower back would tend to get tired when I rode without a backrest.
Old Jan 27, 2025 | 07:13 AM
Notgrownup's Avatar
Notgrownup
The hand position is extremely important imho. I’m on my 4th set on 2 trikes.
Old Jan 27, 2025 | 07:21 AM
TexasScooterTrash
Yer looking for answers without all the information. NO, I don't use a backrest. It's a SEAT issue. I'd say remove the backrest and try some 50's technology. A KIDNEY BACK SUPPORT.
Old Jan 27, 2025 | 07:30 AM
Rains2much's Avatar
Rains2much
This varies per person apparently. I need to be slightly leaned forward to the bars for performance riding. When cruising if you set things up right I can adjust from slightly leaning forward to slightly slouching pushing my heels on the forward pegs. This gives me the ability to handle aggressively and Bing able to shift my body weight to slouching back changing the weight distribution. NEVER would I have my hands as high as my shoulders.. that would be a third back surgery real fast and no chance of performance control. It would have my back straight up receiving the poundings of the road and all the vibration.. less control of body position.
think of your thighs and back like this “<“ going down the road. Now your hips adsorb allowing you to hinge or flex with the bumps and vibration.
‘’You need a little slack in your arms to feel lose, be able to counter steer, and stay loose through tight curves. Allowing you to tense and pull yourself to shift. I go from my foot center on the pegs and tight into the carb and gas tank for hard launches and cornering.. and then sit wide and relaxed for mile after mile.
Old Jan 27, 2025 | 07:50 AM
mseawell1022
@Rains2much Thanks for the feedback.
Old Jan 27, 2025 | 09:06 AM
Keithhu's Avatar
Keithhu
Thanks in advance,
Mark
Everyone is different, for me personally taller bars solved this problem. I had 14s when I had a Heritage, and also when I had a Road King. No issues at all with comfort and for me only a slight bend at the elbow. I went to 12"s on my first Road Glide, that was fine, but on this one I only rolled them forward because I really didnt want to spend a ton of money on it. They are fine. The wrist angle isnt perfect, but not worth spending a ton of dough to correct. Rolling them forward made them a bit taller and of course further away, but it seems to work for me.
Old Jan 27, 2025 | 10:44 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
A semi decent place to start is to have the bike upright, sit on it, with your eyes closed, and hold your hands out in a roughly comfortable position. Now open your eyes snd look at your hand position, including wrist position. See if you can find bars that will roughly get you there.
Where you start from that may not be where you end up. I tend to reach out further and higher doing that than I actually find comfortable, especially for long day rides.
You’ll also likely find yourself having to compromise things. My wrists prefer a lot more pull back angling for comfort, but I find I prefer a straighter, more dirt bike bar for control.
