Steering head grease
Old Sep 9, 2007 | 10:25 AM
JeepMaker's Avatar
JeepMaker
Default Steering head grease
I know the service manual says to use "special purpose grease", but I am thinking that any "normal" grease gun cartridge should be fine. Am I correct, or full of pewp?
Old Sep 9, 2007 | 10:28 AM
UltraDuke's Avatar
UltraDuke
Default RE: Steering head grease
I picked up a tube from the dealer for about six bucks. It is regular wheel bearing grease, you can get it in the tube or in the tub.
Old Sep 9, 2007 | 10:55 AM
grumpy irish again's Avatar
grumpy irish again
any grease will work just don't put in to much I did and still am cleaning up the mess it makes after about 6/8 months but it is getting less every ride..
[IMG]local://upfiles/5757/E48F84E3D8BF4C95920317AD772D2394.jpg[/IMG]
Old Sep 9, 2007 | 12:23 PM
electaRICK's Avatar
electaRICK
it does matter somewhat,, as some grease will "melt" per say on hot days and run out making mess,,,
someone should chime in on what works best,,, I heard marine grease
Old Sep 9, 2007 | 12:35 PM
LowriderFXRS's Avatar
LowriderFXRS
I use Amsoil synthetic chassis & bearing grease.
Old Sep 9, 2007 | 03:37 PM
dog155's Avatar
dog155
That bearing done right may never need to be changed.It is a stout bearing for the job it does.Any good grease is fine.
Old Sep 9, 2007 | 04:27 PM
lbjohnson1's Avatar
lbjohnson1
ORIGINAL: LowriderFXRS
I agree the Amsoil is what I use, Harley-Davidson wheel bearing & special purpose grease is good, also Bel-Ray grease works good. As for amount squirt it in using a grease gun at the grease fittinguntil you see it starting to come out at the bottom of the neck.
Old Sep 11, 2007 | 05:38 PM
fishcop's Avatar
fishcop
It also depends on the temps that you ride in. The dumb asses at a certain HD dealership here in vegas put in regular grease and it melted and melted and melted all down the forks. I finally had to pump it out with hi-temp wheel bearing grease. So yes it can make a difference.
Old Sep 11, 2007 | 05:46 PM
cwilks's Avatar
cwilks
We don't NEED no stinkin' grease
Old Sep 11, 2007 | 06:11 PM
06train's Avatar
06train
Good grade of lubricant will work..My bike is still oozin the **** out from the dealer..
