Pleeeeeeeeeeeeease Listen - OLD POST
Old Jun 20, 2007 | 10:36 PM
  #41
Arcane's Avatar
Arcane
Default RE: Pleeeeeeeeeeeeease Listen - OLD POST
I will agree with what you have to say Terry, but the whole situation of getting a SERT or PC III to really perform is based on access to a knowledgeable and dedicated dyno man. Unless of course you get a map that just happens to be perfect for your particular set up. For one that lives in a state that has six HD dealerships and none with a dynamometer it forces you to find and Indy with a dyno, and guess what, there are five here and none are real good. For those that have access to a great dyno man treat them like gold because they are really hard to find. Early next spring the warranty expires on my 06 Wideglide and I will install a 98 or 107 cubic inch kit. So I am going to go ahead and replace my PC III with a Thunder-max with Auto-tune. For me, if it works like it is claimed to, then it will be money well spent. You are right, high performance is costly, and going high performance with reliability is even more costly. But if you want to play, you’ve got to pay.
Arcane
Old Jun 20, 2007 | 10:41 PM
  #42
Dalton's Avatar
Dalton
I'll let you guys iron out who is cheap, stupid and whining. (BTW, I can be all at times)
Since this thread is two years old, and Terry gave great advice, i am just adding to it, The DTT TCFI II and the T-Max Autotune are definitely state of the art when it comes to tuners,and they aren't married to the stock ECM. Endless tuning capabilities, wide band O2 sensors and so far, good reliability. Weren't available when this thread was originally written.
Old Jun 20, 2007 | 10:42 PM
  #43
cardboard's Avatar
cardboard
ORIGINAL: Arcane
Arcane
Well said ! I got about10 harley dealers in a 125 mile area. One does not have a dyno. Most of them that does, the dyno machine is broke. I know a mechanic that spent 2 yrs with H-D in performance. He is one of the only peope I know that can open the program on a sert and understand the program. Its a very large program and most tuners don't understand it little on dynoing. Make changes to yer bike and yer back to square!
I have the TM A/T and couldn't be happier.
Old Jun 20, 2007 | 10:44 PM
  #44
slack's Avatar
slack
ORIGINAL: cardboard
Race tuner list for around 460 and dyno time is 300 or so when I had one. It could change from dealer to dealer.
Hey thanks I'll check around at the dealers here to see what it will run me. At least now I have a ballpark figure.
Old Jun 20, 2007 | 10:48 PM
  #45
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Please Listen - OLD POST
OK,
First of all, quit fighting. I don't want to have to lock one of my own posts that is almost 2 years old. Hell, I doubt if I could have found this one even if I remembered it.
Some one on the last page made a statement that Harley's run fine out of the box. It's just when you start adding pipes and stuff like that that you have to spend a lot of money. Obviously that person doesn't own an 07. You can fry an egg on an 07 that hasn't been properly tuned. Hell, my $23,000 2000 Road Glide barely made 70 hp with the stock EPA crap on it.
Old Jun 20, 2007 | 10:54 PM
  #46
cardboard's Avatar
cardboard
ORIGINAL: Terry1955
OK,
Some one on the last page made a statement that Harley's run fine out of the box. It's just when you start adding pipes and stuff like that that you have to spend a lot of money. Obviously that person doesn't own an 07. You can fry an egg on an 07 that hasn't been properly tuned. Hell, my 23,000 2000 Road Glide barely made 70 hp with the stock EPA crap on it.
For warranty purposes I had the dealer git me a set of D&D 2-1 pipes with a quiet baffle and the SE high flow box and the TM with A/T and install it. I got 78hp and 82 tq. not bad for a 07 out of the box
Since then I've done a 103 indy build and pushing 103 tq in 4th gear.
Old Jun 20, 2007 | 10:55 PM
  #47
WouldBeHD's Avatar
WouldBeHD
I use the SERT and think it is a great piece of equipment (though I was pissed when I found out that you had to buy the cabling separate). It is actually much cheaper than most car tuning solutions with similar functionality, and MUCH less expensive than a standalone ECU+O2 sensors. If you want to play, you're going to have to pay, no matter what type or brand of vehicle you are talking about.
That's all fine and good. What I'm most curious about is this 117ci monster mentioned in the initial post. What motor is this, how much does it cost, and where would one go about buying one?
Old Jun 20, 2007 | 11:00 PM
  #48
cardboard's Avatar
cardboard
I missed that part but these folks are offering good numbers. Check them out. I know the S&S 117 Side winder motor is screaming but don't know if it will fit yer bike.
http://www.revperf.com/
Old Jun 20, 2007 | 11:05 PM
  #49
tread's Avatar
tread
10-4 Terry
Old Jun 20, 2007 | 11:08 PM
  #50
cardboard's Avatar
cardboard
Thread, don't mean to change the post but I see you have a forged wheel on the front of yer bike. Did you take a spoke off and are you glad you spend the coins for it. Thanks.
