Getting to much vibration
Old Sep 22, 2007 | 06:35 AM
robandlyn's Avatar
robandlyn
Default Getting to much vibration
Hi All
Figured I would post here first and see if anyone has an idea what to check next.
Wife has an 02 Dyna FXD and just had her 30,000 mile service. I had them check
the cam tensioners and sure enough the inside one was ready to destroy itself (the
outer one was worn but within spec). I had them replace it with HD's new super kit
which has new cams, chains, cam plate and higher output oil pump. I also had them
go through the carb because it was running real rough (alot of vibration) and we thought
maybe some crap got into the jets. Well we got it back and the Wife noticed it STILL
is running rough and maybe even worse than before. I ran it up to 60+ MPH and pulled
in the clutch and it ran smooth. So I figured it wasn't a wheel weight (balancing) problem.
What I mean buy running rough is ..... It was like riding her 2000 Sportster !
She has forward controls with floorboards and you can FEEL the vibrations pretty
bad in them where as before it was nice and smooth. I was thinking could it be some type
of timming is off ? Or could it be a motor mount is loose or going bad ?
I have another set of plug wires and I was going to switch them and see it it helped.
This problem was happening even BEFORE she had the work.
Any Ideas ?
Thanks ....
Rob ....
Old Sep 22, 2007 | 06:46 AM
electaRICK's Avatar
electaRICK
Default RE: Getting to much vibration
hey rob,, I see you are on a electra glide......
I to own a Ultra and a 03 Dyna.....which has 20,000 miles....
I ride the Dyna seldom,,, but when I do get on it,,, I feel LOTS of vibration through handle bars,
forward controls,seat......
its like wow,, I cant remeber this being so ruogh..... but I see no probs,,, I wrote it off as nature of the beast,,, and nothing compares to a Ultra Classic!!!!!
Old Sep 22, 2007 | 07:19 AM
robandlyn's Avatar
robandlyn
We both own 2 bikes ....
I also have a 99 FXDWG with a 1550 Stage 2 kit and it does not even have hardly
any vibrations from either the seat, pegs or handlebars .....
There is definatly something wrong ....
Rob ....
Old Sep 22, 2007 | 07:59 AM
dswansbiker's Avatar
dswansbiker
Motor mounts worn out or needing adjustment would be my bet.
Old Sep 24, 2007 | 08:29 AM
rh8234's Avatar
rh8234
My 03 FXD started vibrating pretty bad recently. It is definately motor related as it dies it in neutral sitting on the side stand between 1800 and 2600 RPM's. Replaced the front motor mount and no change. When I ride, hands get numb after about 25 miles. I plan on checking rear motor mount next weekend.
Old Sep 24, 2007 | 10:17 AM
grimm's Avatar
grimm
have you checked the rubber mounts? they could be worn......
jcsurf
Mar 24, 2020 03:46 PM
blades11b
Engine Mechanical Topics
Mar 1, 2014 08:37 AM
Rydertp
Feb 7, 2013 05:20 PM
lazmorph
May 7, 2012 09:00 PM
mplecha
Aug 16, 2009 04:49 AM
