Checking crankshaft runout
Old May 7, 2012 | 04:13 PM
lazmorph's Avatar
lazmorph
Default Checking crankshaft runout
I have a 2008 FLHX street glide that has a fairly large vibration between 1200-1800 rpm's, mostly on deceleration
I have replaced the front motor mount with a GlidePro, Also I have checked that the exhaust bracket is free of defects and made sure that the floor board mount isnt coming in contact with the exhaust.
Yet I still get the vibration.
I had the bike dyno'd at the local Harley dealer and was told this was normal, although no other street glide I've noticed has half this much vibration.
I wanted to check the crankshaft runout (and anything else you guys suggest), but I'm not sure if you have to pull the cam plate to check it, or can you just pull the chain and gears and check runout from there?
Any help or suggestions?
Old May 7, 2012 | 04:38 PM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
With the dial indicator that I have, yes you would have to pull the cam plate to check runout. Not a machinist, and am sure there are indicators available that you would not have to pull the plate, but not exactly sure. I should also mention that I have a 99, so checking runout was more of a formality while in there for the tensioners and cam swap.
Is there any other work done to your ride? Vibration only in 12-1800 range? I would figure that if the crank was causing your vibes, it would get worse with RPM's, not just in a certain range. Let me restate that; I am 99% certain that if the crank was the problem, it would get worse with RPM.
Old May 7, 2012 | 04:47 PM
lazmorph's Avatar
lazmorph
No other work done to the bike that I know of. I just bought it in October. After the crankshaft runout check my next course is going to be to replace the rear mounts with the Glidepro system. Im up for any suggestions.
Old May 7, 2012 | 04:54 PM
jcb1975@yahoo.com
I would be looking at the tune of the motor since it only happens in that low rpm range. Motor mounts too, but would not figure that. As far as runout, well it won't hurt to look at it, but not likely.
Whats the chance that the dealer you bought the bike from is also the one who told you that the vibration was normal?
Old May 7, 2012 | 05:25 PM
lazmorph's Avatar
lazmorph
I bought the bike from a guy in LA and took the bike to be tuned here in Ga.
The bike runs great, except for this vibration issue.
Old May 7, 2012 | 06:08 PM
jcb1975@yahoo.com
For whatever it is worth, I recently put Andrews 26's in my bagger. Had vibes from about 1500 down to idle. A little adjusting to my Power Commander, and problem solved.
You really need to figure out what has been done to that motor. Give the guy you bought it from a call if at all possible. If you already have a tuner installed, aftermarket air cleaner, and whatever else are good things to know. Will save you some time and likely some money. Can tell from your picture that it is not all original, and usually a tuner, pipes and A/C are the first things done to the bike.
Old May 7, 2012 | 07:36 PM
lazmorph's Avatar
lazmorph
Yeah, it has a screaming eagle a/c, v&h 2into2 big radius pipes, SERT, (also used to have a v&h fuel Pack for whatever reason).
I had Harley remove the fuel pack and dyno/tune the bike with the SERT.
But still the vibes as mentioned above.
Old May 7, 2012 | 08:11 PM
speakerfritz's Avatar
speakerfritz
1200 - 1800 is a pretty low operating RPM....you need to raise the bar on your shift points. I would red line anything below 2000 on a touring bike unless you have had your sprockets changed.
Old May 7, 2012 | 09:00 PM
rocknrod's Avatar
rocknrod
Ditto
I try never to go below 2500 RPM unless I to come to a stop.
75IronHD
Engine Mechanical Topics
15
Aug 18, 2016 11:44 AM
Chopperguy99
EVO
Mar 31, 2013 09:58 AM
dntfxer
Mar 23, 2012 04:43 AM
breneau
Oct 28, 2010 09:31 PM
harleywindrider
Aug 14, 2007 10:32 PM
