Dyna Power Commander
Old Oct 21, 2007 | 12:48 PM
geedub's Avatar
geedub
Default Dyna Power Commander
I have some problems running lean and have been recommended Dyno power commander by HD- what is the general feeling or opinions on the Dyna Power Commanderon a 2000 harley ultra classic?
Thanks in advance
Old Oct 21, 2007 | 01:34 PM
marcss's Avatar
marcss
Default RE: Dyna Power Commander
I think they meant a Dyno tune and Power Commander install. That's surprising since the SERT is what Harley Dealers usually reccommend.
What are"lean problems"? Your Harley is fuel injected, right?
Old Oct 21, 2007 | 02:02 PM
geedub's Avatar
geedub
Yes - is the sert a HD stock item?
Old Oct 21, 2007 | 02:11 PM
ChromeJunkie's Avatar
ChromeJunkie
No the SERT (Screamin Eagle Race Tuner) is not a stock item, however, your local dealer may have it in stock. Last I heard the SERT retails for $459, plus however much they charge for a dyno tune....Usually somewhere in the neighborhood of $600, at leastin my area. A PCIII lists for around $350, but can be found for around $250 if you shop around. I would recommend the PCIII, especially if money is tight, not to mention it is much more user friendly than the SERT.
Old Oct 21, 2007 | 04:58 PM
geedub's Avatar
geedub
The lean problem - when its cold it backfires and chokes up alot - it takes 20 minutes to warm up and them 95% of problems go away - I also have problems where certain rpm levels still choke up when the bike is warmed up. Part of the problem the HD dealer says is because someone put on a SE aircleaner but not the pipes or computer.
ORIGINAL: marcss
Old Oct 21, 2007 | 05:12 PM
sugarbear's Avatar
sugarbear
You don't say what you are riding. I doubt what the dealer said is true. It is according to what you want to spend, a cheap fix is a pcIII and a canned map
Old Oct 21, 2007 | 05:46 PM
geedub's Avatar
geedub
2000 Ultra Classic - the dealer is suggesting the pcIII and a canned map.
pillows
Mar 22, 2012 08:39 PM
VRODPAUL13
Screamin Eagle CVO Models
33
Jan 13, 2008 07:45 PM
WAYNERR
May 17, 2007 07:16 PM
IRready
Exhaust System Topics
13
Apr 30, 2006 01:19 PM
2006ultra
Mar 26, 2006 09:30 AM
