A couple of ? about Mustache engine guard.
Old Oct 27, 2007 | 08:22 AM
tmitchellof PG's Avatar
tmitchellof PG
Default A couple of ? about Mustache engine guard.
I have a SE Fat Boy, which comes with 2" longer foot boards. This means that a lot of the engine guard models will notclear the foot boards,on my bike. I have read where the Mustache model will work.
My first choice would have been the Kuryakyn ergo guards, where they have an optionalmounting kit, forrunning lights and are set up with holes to run wires through them. I read somewhere thatthis modelwont clear my foot boards.
The reason I would add an engine guard, would beso I could attach running lights. This along with the headlight would achieve the triangle light pattern, that makes the bike more visible to oncoming traffic.
It may also helpto save some paint and chrome, if I were to drop the bike in the garage,etc.
My questions are:
Has anyone ran wires through the guard and attached lights to the Mustache?
Are the rubber foot pads easy removable?
If anyone knows of any aftermarket engine guard that will fit an SE Fat Boy, I would appreciate the information.
Thanks,
Tom
Old Oct 27, 2007 | 09:22 AM
Coaster's Avatar
Coaster
Default RE: A couple of ? about Mustache engine guard.
I just installed this a few months ago http://www.granpas.com/HighwayBar.htm
I have 3 inch extensions on my floorboards and this works fine. I'm not sure though if you would have enough length to mount lights on them. I installed them mainly for the pegs so I could stretch out more on highway rides.
Call him up. I talked to Bob when I called and he's the owner of the biz. He makes these and I bet he can answer all your questions. He might even have another option if they don't work for you. Great personal service with him and the bars are top notch quality made here in the US worth the money imo.
Old Oct 27, 2007 | 02:12 PM
tmitchellof PG
Thanks for the reply. I don't think that setup would work for attaching running lights.
Tom
Old Oct 27, 2007 | 05:41 PM
rde's Avatar
rde
I just ordered the Mustache engine guard for my Road King. I haven'treceived it yet, but once I check it out I can let you know about the foot pads, etc.
Old Oct 27, 2007 | 06:30 PM
warthawg's Avatar
warthawg
I just installed the HD Mustache guard on my Heritage and there is plenty of room from the end of floor board to the guard. As you can see the HD Guard is angled foward and is below the bottom of the floor boards. Don't know how much difference there is in the Heritage setup and the SE Fat Boy, but hopefully the pic will give you some idea.
Old Oct 27, 2007 | 06:56 PM
Still running's Avatar
Still running
I've got a Linby , thats not spelled right. Here's a pic.
Old Oct 27, 2007 | 06:59 PM
combat_vet's Avatar
combat_vet
The step pads are glued to the top of the Mustache engine guard and would be difficult to remove. The standard HD fog lights will not work on the guard, so you would have to install Kury's or Motolights on the bike for additional lighting.
Old Oct 27, 2007 | 09:35 PM
tmitchellof PG
Thanks for the replies.
What I would like to do, is pull the foot pads off the Mustache engine guard.Mount aftermarket rectangular running lights on the bar, right below where the pads were. Drill whatever holes in the bar are necessary, to mount the lights. Drill a hole where the pads were removed, on top, big enough to get nuts and washers onto the attachment studs for the lights.Put the rubber pads back on to cover the open holes. Then fish the wire up the inside, to the top part of the bar, up to where it attaches to the frame. I was wondering if anyone else has done anything similar to this?
The whole purpose is to get the proper trianglespacing with the lighting. The Mustache engine guard just providesa place to mount the lights.
Tom
Old Oct 28, 2007 | 12:12 AM
PapaTravis's Avatar
PapaTravis
ORIGINAL: tmitchellof PG
Tom
Have you thought about those moto lights? They attach to your downtubes, and I hear they are great. Plus, lifetime on the lamps. You might want to check them out, as an option.
Old Oct 28, 2007 | 03:34 AM
flhx74's Avatar
flhx74
Keep your mustache away from the engine at all costs...
