Battery Problems
Old Nov 7, 2007 | 01:54 PM
GoNoles82's Avatar
GoNoles82
Default Battery Problems
Does anyone else have problems with your original stock battery on your bikes? Mine discharged once, and now it's not holding a charge for more than 1 or 2 days or so. The dealer says it's fine, but it definitely has to be recharged constantly. I'm thinking it needs a new battery, but it's only an '06.
Old Nov 7, 2007 | 02:04 PM
Amodump001's Avatar
Amodump001
Default RE: Battery Problems
did you check your charging voltage? should last longer than two years but then again??
Old Nov 7, 2007 | 02:09 PM
oldgeezer's Avatar
oldgeezer
Are you just riding it to charge it or are you putting it on a tender? I would try putting it on a tender when you aren't riding it. Do that for a couple of weeks then leave it off and see if that helps.
Old Nov 7, 2007 | 02:21 PM
Shaw_2112's Avatar
Shaw_2112
I had a similar problem. Left the lights on by mistake once and the batt wouldn't hold a charge after that. Chuck it and get a new one...
Old Nov 7, 2007 | 02:38 PM
redscout's Avatar
redscout
I know I'm just asking to get stranded.... but mine has the stock battery still in it from when I bought it new. In October of '02...
Never had a bike battery last that long.
Old Nov 7, 2007 | 03:05 PM
Dorkman's Avatar
Dorkman
If its not holding a charge you are on borrowed time. Battery tenders are great, and recommended, but won't save a battery that will not hold a charge.
Did the dealer test the battery and the charging system to arrive at his "fine" determination? The other possibility is thata short is drawing down the battery. They should also be able to determine if current flows with the key off. The battery should last longer, but failures are not unheard of. Its a likely suspect.
Old Nov 7, 2007 | 03:31 PM
ChromeJunkie's Avatar
ChromeJunkie
I had to replacethe battery on my 06when the stator went out at 20,000. As mentioned above, havethe dealercheck out your charging system.
Old Nov 7, 2007 | 03:35 PM
pip369's Avatar
pip369
I had a stock battery go out after about 2 years. I replaced it with another HD battery and also started using a battery tender. Since then have not had any battery problems. I use a battery tender on all my bikes as well as the lawn mower. Tried it on the Tahoe but didn't work very well...I ended up replacing that battery.
Old Nov 7, 2007 | 04:08 PM
dog155's Avatar
dog155
No battery problems since started using Battery Tenders.
Old Nov 7, 2007 | 07:52 PM
pepesworld's Avatar
pepesworld
I am on my third battery!....the first two only lasted about five years each. Never put them on a tender though. It was getting where the bike would take a while to start after sitting for a few months over winter. I put in fresh plugs this year....starts just like new again.
Farmboy135
Jul 25, 2025 06:20 AM
fRESH88
Oct 23, 2019 03:51 PM
pd76
EVO
13
Feb 14, 2009 10:30 PM
caorig
Apr 27, 2008 07:29 PM
fxdbi4me
Jan 15, 2008 04:44 PM
