Windshield Question
Old Nov 8, 2007 | 10:41 PM
Drclev3's Avatar
Drclev3
Default Windshield Question
Does anyone know who makes a short windshield for a heritage classic? I have a stock one which is 20"I think and want one 2 or 3" shorter.I did a serch on it but there were too many threads to read through so I thought I would ask some of the wise men and women on here.
Thanks in advance
Old Nov 8, 2007 | 11:02 PM
TxHarleyGuy2007's Avatar
TxHarleyGuy2007
Default RE: Windshield Question
http://steelhorsewindshields.com/cat...hp?cPath=79_25
Low profile windshields.
Old Nov 8, 2007 | 11:43 PM
cHarley's Avatar
cHarley
Try Memphis Shades forthe "Fats" model. Their mounting brackets have the same shield bolt pattern as the HD brackets. You can by the plastic shield only and reuse your existing HD brackets. http://www.memphisshades.com/fats_harley.shtml
Old Nov 8, 2007 | 11:51 PM
Bowtieman31's Avatar
Bowtieman31
Why waste your money buying another windshield? These windshields are very easy to cut down. Just measure the height you want, mask it off with a good masking tape or duct tape and cut it with a sabre/jig saw or roto-zip tool, sand the edge smooth and you're done. You can do that job in about an hour and save yourself a couple of hundred dollars.
Old Nov 9, 2007 | 04:22 AM
whaap's Avatar
whaap
If you're reluctant to do it your self, most glass shops will do it for you.
Old Nov 9, 2007 | 05:20 AM
qwest's Avatar
qwest
ORIGINAL: whaap
I measured and marked my windshield then took it to a glass shop. They did an unbelievably good job on it. Cost me $25.
Old Nov 9, 2007 | 10:05 AM
Drclev3's Avatar
Drclev3
Thanks for the advice. I think I will go the route of trying the glass shop. I have one right down the road from me I will bring it there and see what they say.
Old Nov 9, 2007 | 12:57 PM
craigcrewcheif's Avatar
craigcrewcheif
I put a big scratch by accident on my Harley Low Profile windshield. I ordered a replacement piece of plastic from Rifle. They have exact replacement sizes or plus or minus 2 inches. You can also special order any size.
Old Nov 9, 2007 | 01:02 PM
sugarbear's Avatar
sugarbear
I took a piece of poster board layed it against the windshield marked the edge and used scissors to cut it. I sat on the bike and had someone lower the poster board to the hight I wanted, measured it and cut it off. pretty simple.
Old Nov 10, 2007 | 11:22 AM
spikehyre's Avatar
spikehyre
CeeBaileys. Aircraft quality and reasonably priced. Far and above HD OEM.
