Any problems with using 10% ethanol?
Old Dec 22, 2007 | 08:48 AM
tmitchellof PG's Avatar
tmitchellof PG
Default Any problems with using 10% ethanol?
The majority of times I fill up the Fat Boy, in town, is at a station, that I just noticed had stickers stating "10% ethanol". I don't know if they just started using Ethanol or I never noticed the sticker. The reason I have been using this station was that they have separate hoses for each octane rating. That way I figure I am getting all premium.
Has anyone had a bad experience using gas that has 10% ethanol, in their Harley's.
Tom
Old Dec 22, 2007 | 08:52 AM
Nightrider2's Avatar
Nightrider2
Default RE: Any problems with using 10% ethanol?
I'm curious as well, we get our 10% ethanol in April of 08
Old Dec 22, 2007 | 08:58 AM
rbabos's Avatar
rbabos
No problem here, other than milage may be down on a tank. Over 10% think about rejet or remap.
Ron
Old Dec 22, 2007 | 09:02 AM
LKHA's Avatar
LKHA
no problem at all. fuel mileage does not drop and the dealer that I bought bike at in MN said no issues with 10% hopes this helps
Old Dec 22, 2007 | 09:52 AM
WGRIDER's Avatar
WGRIDER
No problems here in VA.
Been running 10% since day one.
Hard to find non 10%.
Over 20k miles on WG.
Hope this helps you.
Old Dec 22, 2007 | 10:08 AM
Bear64's Avatar
Bear64
no problems 157,000 on FLHT,
Old Dec 22, 2007 | 10:16 AM
CAPTIAN BUZZ's Avatar
CAPTIAN BUZZ
No problems here. I'm with you on the multiple hose pumps. The one hose pumps you get at least what is in the hose of what ever the person before you used (most likely lower grade gas).
Old Dec 22, 2007 | 11:38 AM
geargrinder's Avatar
geargrinder
In rare examples, if you are on the ragged edge of vapor lock or being too lean, 10%alcohol (ethanol)added to fuel could push you over the edge. Also, you will notice a slight decrease in fuel mileage. Other then this, no problems ifthe stationsells enough of it, alcohol does separate from fuel if stored for long periods of time, not good, but again not common.
Old Dec 22, 2007 | 12:20 PM
biz44's Avatar
biz44
IIRC the owners or service manual says to not use any fuel with more than 10% ethenol.....I have never seen a pump in the NYC/North Jersey area with a listing of more than 10% though.
As far as stations with one hose for all grades. If you want to be 100% sure your getting all 93 octane or whatever.....just wait until you see a car in front of you getting the super and then fill up right after him.....u know what i am saying.
Old Dec 22, 2007 | 12:27 PM
Hops's Avatar
Hops
Hess is the only Branded stations at this time that have the 10% ethanol here in middle FL. Gas that comes out of Tampa covers from Gainesville to Ft Myers, and coast to coast. Pilot truck stops and Race Track are also using the ethanol. Some of the Unbranded stations could be using it as well, I think Sam's club andWalmart are usingalso.Most of the other terminals will start adding ethanol shortly. The ethanol has been eating away the plastic sight glasses on the trailers. As far as the separate hose deal, I guess if it makes you feel better, that is all that matters. But I don't see much of an issue. The octane rating on the pump is supposed to be the minimum rating for the particular grade.
ORIGINAL: tmitchellof PG
Tom
