antenna replacement
Old Jan 5, 2008 | 01:11 PM
electraglide in blue's Avatar
Stage III
Default antenna replacement
I have a 2007 ultra classic and want to replace antennas with the 13"
or the 18". Which would you recommend.Is one better than the other?
I was going to get J&M antennas.Is there another brand better? Just looking for ideas.Thanks electraglide in blue
Old Jan 5, 2008 | 02:15 PM
Rodent's Avatar
Rodent
Default RE: antenna replacement
There are a lot of antenna's out there. I would suggest J&M's. Good antenna and FLEXIBLE.
Some companies have stainless steel ones, but if they get bent, you're screwed.
Old Jan 5, 2008 | 02:20 PM
PSO169's Avatar
PSO169
Go Cheap
I went to Auto Zone and bought two smaller rubber antennas for less than $20.00. I have not ever used the CB so I dont know if they work on the CB. I like the look and fact that I dont drag the top of the garage on the way in.
Jeff
Old Jan 5, 2008 | 02:35 PM
BinIdaho's Avatar
BinIdaho
Auto Zone...think the one I have was $4.99. They're the same as J&P for lot less. Had 'em on the Ultra last year.
Old Jan 5, 2008 | 03:14 PM
rinja64's Avatar
rinja64
For Christmas I got the ones from EGLIDEGOODIES.
http://www.eglidegoodies.com/id10.html
Old Jan 5, 2008 | 03:16 PM
Black Lion's Avatar
Black Lion
I just took the stock antennas and cut them down. Looks good and costs nothing.
Old Jan 5, 2008 | 03:17 PM
Stash's Avatar
Stash
I've had J&P's for the past year. You will lose range on both FM and CB reception. FM reception will drop on the "fringe" areas. CB broadcast and reception is not more than 1/2 mile. I ride several "large" rides (35 plus riders) each year, so it's easy to compare the different systems. J&P's look good, but in this case, bigger is better.
Old Jan 5, 2008 | 03:23 PM
PhoenixClassic's Avatar
PhoenixClassic
I put the ones from AntennaX on mine and they are fine. Less than $20.
I only use the FM - haven't tried the CB.
Old Jan 5, 2008 | 11:41 PM
goodbirds's Avatar
goodbirds
I tried the eglide goodies version, but the CB antenna broke eventualy from too much flexing. AM/FM was fine. I replaced the CB with the J&M one, and it works real good. Better design and more effective too. I will replace the AM/FM antenna too, for the identical look, but it won't be an improvement in reception.
Old Jan 7, 2008 | 06:05 PM
dbird's Avatar
dbird
ORIGINAL: electraglide in blue
I have two used but like new $15.00 plus shipping. Paypal williamj@alltel.net
