Shifting into neutral????? update
Old Jan 25, 2008 | 03:30 AM
  #41
99octane's Avatar
99octane
Default RE: Shifting into neutral????? update
I have a similar risky situation I must go through every day: my garage is in an underground silo together with many others, and it's right after the bend. I have to stop to open it, and have to stop on the "blind" side (i.e.: the internal side of the bend, where I'm less visible), so I always put the blinkers on when I'm stopped, so that anybody coming will see the blinking yellow light and will slow down.
Old Jan 25, 2008 | 03:32 AM
  #42
whaap's Avatar
whaap
ORIGINAL: Geoseismic
Clutch in, ready to roll! I also keep enough space in front of me to roll around if required!
That's two of us.
Old Jan 25, 2008 | 03:42 AM
  #43
jimmers1817's Avatar
jimmers1817
Msf taught me to stay in first ready to roll. Same thing with emergency stops, gotta be in first when you come to a stop.
Old Jan 25, 2008 | 05:05 AM
  #44
BadBoyFLSTC's Avatar
BadBoyFLSTC
ORIGINAL: brentf
Depends on the red light, if it is a busy intersection and a very long light then neutral it is. If it's a short light keep the clutch in .
Here too.
Old Jan 25, 2008 | 05:26 AM
  #45
deadman77's Avatar
deadman77
Usually neutral.
Depends on the situation.
Ever had a clutch cable break?
Not a good thing.
MikeM
Old Jan 25, 2008 | 05:38 AM
  #46
biz44's Avatar
biz44
I didnt ask this question with a safety aspect in mind. I asked it from a mechanics point of view. I know changing out a clutch is not all that hard a job, and replacing the clutch could be a good thing in some cases where you been wanting a better performing unit, or stiffer spring/s whatever....even a easy pull spring.
I just hate to put unnecessary wear and tear on the clutch....thats why I asked.
Like I said.....personally I always put the bike in neutral as soon as I know there is a car behind me blocking.....and if the road is clear, and the light is long, it goes into neutral even if there is no car behind me....I just ride the mirrors.
Old Jan 25, 2008 | 05:52 AM
  #47
sporty2003's Avatar
sporty2003
i try my best not to stop if i dont havta.
Old Jan 25, 2008 | 05:53 AM
  #48
BadBoyFLSTC
ORIGINAL: biz44
Once the clutch is disengaged there shouldn't be any more wear on it as long as it's held in. In fact, since you are doing it twice by shifting to neutral every time, aren't you putting twice the wear on it?
Old Jan 25, 2008 | 05:55 AM
  #49
BadBoyFLSTC
Nuthin to see here
Old Jan 25, 2008 | 05:57 AM
  #50
farns's Avatar
farns
Neutral - most of the time.
Heavy traffic with lots of cityots, I wait until the car behind me stops, then neutral.
