Help troubleshoot - engine backfiring
Old Feb 8, 2008 | 02:40 PM
JeckyllPhD's Avatar
JeckyllPhD
Default Help troubleshoot - engine backfiring
2003 Sportster 883 is backfiring today. Just got the bike. It ran fine three days ago (warmer weather). Today is colder, but engine is plenty hot. Runs better with choke out. When choke is in it starts to miss and backfire.
Added premium gas, but same thing. Any suggestions? Thanks guys!
Old Feb 8, 2008 | 02:43 PM
anubisss's Avatar
anubisss
Default RE: Help troubleshoot - engine backfiring
Pull the plugs and see how they look.
Old Feb 8, 2008 | 02:46 PM
dog155's Avatar
dog155
After you check the plugs or change them, the only other thing it could be is a fuel delivery problem.Especially having to run with the choke out.
Old Feb 8, 2008 | 02:51 PM
The Baron's Avatar
The Baron
Colder weather requires richer jetting because the air is denser.
First make sure the fuel screw didn't fall out. If someone already messed with it and pulled the plug they may have turned it too far out and the vibration shook it loose.
If it's there, turn it in until it's lightly seated, counting the turns. You don't want it to be more than 2-1/2 turns out otherwise it could fall out.
Try turning it out to get the bike to cease the popping, if it gets better the further you turn it out, try a larger pilot (slow) jet.
Old Feb 8, 2008 | 02:55 PM
FastHoss's Avatar
FastHoss
Had that happen to me once with a Sportster I had,turned out I had upgraded spark plugs,bad idea,went back to what was in it ,end of problem
Old Feb 8, 2008 | 03:16 PM
csbreeze's Avatar
csbreeze
Did you put pipes and a new Air cleaner on a stock bike? Stage 1 in other words? If so and you have a carb you have to get the jets worked on. If not something may be wrong with your carb.
Thats my 2 cent.
Old Feb 8, 2008 | 04:30 PM
JeckyllPhD's Avatar
JeckyllPhD
where is the fuel screw? sorry I'm kinda new at this
Old Feb 8, 2008 | 06:17 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
buy some new sparkplugs, make sure the gap is set (.040 in.), install the plugs, when starting the bike pull the enrichener **** out full if it's 60 degrees or cooler, once the engine is running, slowly push the enrichener in about halfway till the motor has warmed to operating temps., then push it in completely, operating the bike with the enrichener out will foul plugs. you may want to visit nightrider.comthen go to motorcycle performance guide for a little intrductory course on the carb. it's a little difficultcdescribe the ins and outs of the carb and its nuances.
Old Feb 8, 2008 | 06:39 PM
steelhorse 1971's Avatar
steelhorse 1971
could possibly be a vacum leak
Aj Leos
Feb 8, 2014 06:44 PM
Rounder1023
Jul 18, 2012 05:09 PM
sportster2009
Nov 9, 2009 05:36 PM
roadkill0000
Oct 23, 2008 06:21 PM
jagular1785
Jun 7, 2008 01:58 AM
