Kill switch then key?
Old Mar 6, 2008 | 07:39 PM
Graduate's Avatar
Graduate
Default Kill switch then key?
Why is it recommended that the kill switch be used first to kill the engine then turn off the key?
Old Mar 6, 2008 | 07:41 PM
pip369's Avatar
pip369
Default RE: Kill switch then key?
My guess is because it is up on the handle bar,,,but that is just a guess.
Old Mar 6, 2008 | 07:45 PM
sortasuave's Avatar
sortasuave
There's no specific reason to do it in this order. However, doing it this way, allows you to keep your hands on the handle bar, and thus the brake. Also, this "habit" would keep you from letting go of the clutch, thus preventing an accidental launch of the bike.
Old Mar 6, 2008 | 07:47 PM
tbone52's Avatar
tbone52
With a Dyna, it's probably safer to kill the engine first with the kill switch before leaning over the bike to reach the key on the neck of the frame while balancing the bike with one hand on the handlebar.
Here's my routine.
Stop the bike.
Put it in neutral.
Hit the kill switch.
Put down the jiffy stand.
Get off the bike.
Turn the key and remove it.
Old Mar 6, 2008 | 08:00 PM
DannyZ71's Avatar
DannyZ71
Wow. For 30 years I just assumed the kill switch was for emergencies while still in motion. And using the key always kept me from walking away with the key still on. [sm=dontgetit.gif]
Old Mar 6, 2008 | 08:06 PM
rtb's Avatar
rtb
The ignition switch "switches" less current if you first shutoff the engine with the kill switch.
Old Mar 6, 2008 | 08:07 PM
HGM's Avatar
HGM
Cant say I've ever used the kill switch.. Good way to kill your battery..
Old Mar 6, 2008 | 08:08 PM
oldairboater's Avatar
oldairboater
There have been several articules hinting at speedo failures and electronics failing from using key switch to kill the bike instead of the kill switch. Also the articules stated that they recommended that the key be turned on and then the kill switch to start the bike. I normally turn the key on let ecm ramp up then turn on kill switch and listen to the fuel pump ramp up then hit the starter switch. I don't really know if it makes a difference but I will continue this till something smarter comes along.
DannyZ71's Avatar
DannyZ71
ORIGINAL: rtb
Okay. I'm not an electrician so please let me know why this is good. I don't mind changing habits if theres a good reason.
Old Mar 6, 2008 | 08:09 PM
DannyZ71's Avatar
DannyZ71
ORIGINAL: oldairboater
Okay, now that makes sense. None of my bikes ever had any electronics except for lights.
